跳转到主内容
Acer Aspire One Cloudbook 11 AO1-131-C7DW Back Panel Replacement
你所需要的
  1. Acer Aspire One Cloudbook 11 AO1-131-C7DW Back Panel Replacement, Back Panel: 步骤 1 中的图像 1,3 Acer Aspire One Cloudbook 11 AO1-131-C7DW Back Panel Replacement, Back Panel: 步骤 1 中的图像 2,3 Acer Aspire One Cloudbook 11 AO1-131-C7DW Back Panel Replacement, Back Panel: 步骤 1 中的图像 3,3
    在这个步骤中使用的工具:
    购买
    • Power the laptop off.
    • Flip the laptop over and position it so the opening faces you.
    • Remove the rubber foot located near the opening side of the device using tweezers.
  2. Acer Aspire One Cloudbook 11 AO1-131-C7DW Back Panel Replacement: 步骤 2 中的图像 1,2 Acer Aspire One Cloudbook 11 AO1-131-C7DW Back Panel Replacement: 步骤 2 中的图像 2,2
    • Unscrew the five 5-mm screws using the PH0 screwdriver.
  3. Acer Aspire One Cloudbook 11 AO1-131-C7DW Back Panel Replacement: 步骤 3 中的图像 1,3 Acer Aspire One Cloudbook 11 AO1-131-C7DW Back Panel Replacement: 步骤 3 中的图像 2,3 Acer Aspire One Cloudbook 11 AO1-131-C7DW Back Panel Replacement: 步骤 3 中的图像 3,3
    • Identify the HDMI port located in the side of the laptop opposite to the power button.
    • Insert the plastic opening tool into the divet of the back panel located above the HDMI port.
    • Pry along the laptop frame until the back panel comes loose.
    • Do not pull the back panel too hard as the battery is still connected to the back panel and the motherboard. This can damage your device.
  4. Acer Aspire One Cloudbook 11 AO1-131-C7DW Back Panel Replacement: 步骤 4 中的图像 1,2 Acer Aspire One Cloudbook 11 AO1-131-C7DW Back Panel Replacement: 步骤 4 中的图像 2,2
    • Rotate the device so the opening faces you again.
    • Hold the back panel away from the laptop and remove the 4-mm screw using the PH0 screwdriver.
    • This screw is fastening the battery to the laptop.
    • Lift the back panel gently.
  5. Acer Aspire One Cloudbook 11 AO1-131-C7DW Back Panel Replacement: 步骤 5 中的图像 1,2 Acer Aspire One Cloudbook 11 AO1-131-C7DW Back Panel Replacement: 步骤 5 中的图像 2,2
    • Unplug the cable that connects the battery to the motherboard.
    • Detach the back panel, which still includes the battery.
结论
另外一个人完成了本指南。
团队
CSU Fullerton, Team S1-G4, Bruce Fall 2017 CSU Fullerton, Team S1-G4, Bruce Fall 2017 的会员
CSUF-BRUCE-F17S1G4
3 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 8
总计 992
