跳转到主内容
Acer Aspire One AO756-2623 LCD Sceen Replacement
你所需要的
  1. Acer Aspire One AO756-2623 LCD Sceen Replacement, Battery: 步骤 1 中的图像 1,1
    • Orient the ACER Aspire One to where the bottom of the laptop is facing upward as shown in the picture.
  2. Acer Aspire One AO756-2623 LCD Sceen Replacement: 步骤 2 中的图像 1,1
    • Locate the circular slot positioned at the bottom right of the battery.
  3. Acer Aspire One AO756-2623 LCD Sceen Replacement: 步骤 3 中的图像 1,3 Acer Aspire One AO756-2623 LCD Sceen Replacement: 步骤 3 中的图像 2,3 Acer Aspire One AO756-2623 LCD Sceen Replacement: 步骤 3 中的图像 3,3
    • Insert a spudger and slide the tab to the right.
    • When working with electronics, it's important to choose a tool that's ESD-safe to avoid accidental damage to the device. The regular black nylon spudger or a plastic opening tool should be used whenever possible.
    • Hold the tab in the right-hand position and firmly push or pull the battery upward to remove it from the laptop.
  4. Acer Aspire One AO756-2623 LCD Sceen Replacement, LCD Sceen: 步骤 4 中的图像 1,1
    • Orient the laptop as shown in the picture with the open screen facing toward you.
  5. Acer Aspire One AO756-2623 LCD Sceen Replacement: 步骤 5 中的图像 1,3 Acer Aspire One AO756-2623 LCD Sceen Replacement: 步骤 5 中的图像 2,3 Acer Aspire One AO756-2623 LCD Sceen Replacement: 步骤 5 中的图像 3,3
    • Insert the spudger into the indicated crease.
    • Firmly slide spudger around the edge of the entire laptop to remove the front plate of the screen.
    • Loud cracking noises from the plastic tabs separating may occur, do not worry, they are to be expected.
  6. Acer Aspire One AO756-2623 LCD Sceen Replacement: 步骤 6 中的图像 1,3 Acer Aspire One AO756-2623 LCD Sceen Replacement: 步骤 6 中的图像 2,3 Acer Aspire One AO756-2623 LCD Sceen Replacement: 步骤 6 中的图像 3,3
    • Identify the four 6 mm Phillips screws that are necessary to remove the LCD screen.
    • Remove all four screws using a Phillips #0 Screwdriver.
    • Pull away the LCD screen from the back cover of the laptop without ripping the ribbon cable connecting it to the bottom of the laptop.
  7. Acer Aspire One AO756-2623 LCD Sceen Replacement: 步骤 7 中的图像 1,3 Acer Aspire One AO756-2623 LCD Sceen Replacement: 步骤 7 中的图像 2,3 Acer Aspire One AO756-2623 LCD Sceen Replacement: 步骤 7 中的图像 3,3
    • Remove the tape covering the port connecting the screen to the bottom of the laptop.
    • To remove the LCD screen, gently pull the cable straight out of the screen.
    • In the first and second photos, the screen is lying face down on the keyboard.
结论
3等其他人完成本指南。
Davis Adams
于03/20/16注册
465 声望
创作了3篇指南
团队
Clemson, Team 7-1, Benson Spring 2016 Clemson, Team 7-1, Benson Spring 2016 的会员
CLEM-BENSON-S16S7G1
4 名成员
创作了14篇指南
一条评论
Spot on! Perfect tutorial thank-you very much!
Sonia Green - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 6
总计 1,006
