跳转到主内容
Acer Aspire One AO756-2623 Keyboard Replacement
你所需要的
  1. Acer Aspire One AO756-2623 Keyboard Replacement, Battery: 步骤 1 中的图像 1,1
    • Orient the ACER Aspire One to where the bottom of the laptop is facing upward as shown in the picture.
  2. Acer Aspire One AO756-2623 Keyboard Replacement: 步骤 2 中的图像 1,1
    • Locate the circular slot positioned at the bottom right of the battery.
  3. Acer Aspire One AO756-2623 Keyboard Replacement: 步骤 3 中的图像 1,3 Acer Aspire One AO756-2623 Keyboard Replacement: 步骤 3 中的图像 2,3 Acer Aspire One AO756-2623 Keyboard Replacement: 步骤 3 中的图像 3,3
    • Insert a spudger and slide the tab to the right.
    • When working with electronics, it's important to choose a tool that's ESD-safe to avoid accidental damage to the device. The regular black nylon spudger or a plastic opening tool should be used whenever possible.
    • Hold the tab in the right-hand position and firmly push or pull the battery upward to remove it from the laptop.
  4. Acer Aspire One AO756-2623 Keyboard Replacement, Back Cover: 步骤 4 中的图像 1,1
    • Locate the single 6 mm Phillips screw in the lower middle of the back plate.
    • Remove the screw using a Phillips #0 Screwdriver.
  5. Acer Aspire One AO756-2623 Keyboard Replacement: 步骤 5 中的图像 1,2 Acer Aspire One AO756-2623 Keyboard Replacement: 步骤 5 中的图像 2,2
    • Slide the back plate downward to remove it from the laptop.
  6. Acer Aspire One AO756-2623 Keyboard Replacement, Keyboard: 步骤 6 中的图像 1,1
    • Locate the eighteen 6 mm Phillips screws that are required to remove the keyboard.
    • Remove all screws using a Phillips #0 screwdriver.
  7. Acer Aspire One AO756-2623 Keyboard Replacement: 步骤 7 中的图像 1,1
    • Orient the laptop to where the open screen is facing towards you.
    • Slide the spuldger into the indicated crease.
    • Firmly slide spudger all the way around the laptop to pry the keyboard away from the bottom of the laptop.
    • Loud cracking noises will be heard during this step.
  8. Acer Aspire One AO756-2623 Keyboard Replacement: 步骤 8 中的图像 1,3 Acer Aspire One AO756-2623 Keyboard Replacement: 步骤 8 中的图像 2,3 Acer Aspire One AO756-2623 Keyboard Replacement: 步骤 8 中的图像 3,3
    • Remove the green dotted ribbon cable by sliding it straight out of the clamp holding it in using a plastic spudger.
    • Locate the two tabs that are holding the larger black ribbon cable in place.
    • Remove the larger black ribbon cable by pressing in the tabs and sliding it straight out of the clamp holding it in using a plastic spudger.
    • To remove the keyboard, lift the keyboard straight away from the rest of the laptop.
  9. Acer Aspire One AO756-2623 Keyboard Replacement: 步骤 9 中的图像 1,3 Acer Aspire One AO756-2623 Keyboard Replacement: 步骤 9 中的图像 2,3 Acer Aspire One AO756-2623 Keyboard Replacement: 步骤 9 中的图像 3,3
    • Locate the ten 6 mm Phillips screws that connect the keyboard to the rest of the laptop and remove them with a Phillips #0 Screwdriver.
    • Locate the four 6 mm Phillips screws hidden beneath black tape by lifting up the black tape and remove them with a Phillips #0 Screwdriver.
    • To remove keyboard from the rest of the laptop, pull keyboard straight up.
结论
另外一个人完成了本指南。
Davis Adams
于03/20/16注册
465 声望
创作了3篇指南
团队
Clemson, Team 7-1, Benson Spring 2016 Clemson, Team 7-1, Benson Spring 2016 的会员
CLEM-BENSON-S16S7G1
4 名成员
创作了14篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 10
总计 1,462
