跳转到主内容
Acer Aspire One AO756-2623 Hard Drive Replacement
你所需要的
  1. Acer Aspire One AO756-2623 Hard Drive Replacement, Battery: 步骤 1 中的图像 1,1
    • Orient the ACER Aspire One to where the bottom of the laptop is facing upward as shown in the picture.
  2. Acer Aspire One AO756-2623 Hard Drive Replacement: 步骤 2 中的图像 1,1
    • Locate the circular slot positioned at the bottom right of the battery.
  3. Acer Aspire One AO756-2623 Hard Drive Replacement: 步骤 3 中的图像 1,3 Acer Aspire One AO756-2623 Hard Drive Replacement: 步骤 3 中的图像 2,3 Acer Aspire One AO756-2623 Hard Drive Replacement: 步骤 3 中的图像 3,3
    • Insert a spudger and slide the tab to the right.
    • When working with electronics, it's important to choose a tool that's ESD-safe to avoid accidental damage to the device. The regular black nylon spudger or a plastic opening tool should be used whenever possible.
    • Hold the tab in the right-hand position and firmly push or pull the battery upward to remove it from the laptop.
  4. Acer Aspire One AO756-2623 Hard Drive Replacement, Back Cover: 步骤 4 中的图像 1,1
    • Locate the single 6 mm Phillips screw in the lower middle of the back plate.
    • Remove the screw using a Phillips #0 Screwdriver.
  5. Acer Aspire One AO756-2623 Hard Drive Replacement: 步骤 5 中的图像 1,2 Acer Aspire One AO756-2623 Hard Drive Replacement: 步骤 5 中的图像 2,2
    • Slide the back plate downward to remove it from the laptop.
  6. Acer Aspire One AO756-2623 Hard Drive Replacement, Hard Drive: 步骤 6 中的图像 1,1
    • Locate the four 6 mm Phillips screws pictured necessary to remove the hard drive.
    • Remove all four of the screws using a Phillips #0 Screwdriver.
  7. Acer Aspire One AO756-2623 Hard Drive Replacement: 步骤 7 中的图像 1,2 Acer Aspire One AO756-2623 Hard Drive Replacement: 步骤 7 中的图像 2,2
    • Locate the two tabs that keep the hard drive ribbon cable connected to the laptop.
    • Using a spudger, gently push in the indicated tabs.
    • While holding down the tabs, slide the ribbon cable to the left to remove it from the laptop.
  8. Acer Aspire One AO756-2623 Hard Drive Replacement: 步骤 8 中的图像 1,1
    • Remove the hard drive by pulling it straight out.
结论
3等其他人完成本指南。
Colin Rodwell
于03/21/16注册
373 声望
创作了3篇指南
团队
Clemson, Team 7-1, Benson Spring 2016 Clemson, Team 7-1, Benson Spring 2016 的会员
CLEM-BENSON-S16S7G1
4 名成员
创作了14篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 8
过去 30 天: 23
总计 2,239
