跳转到主内容
Acer Aspire One A150-1570 Keyboard Replacement
你所需要的
  1. Acer Aspire One A150-1570 Keyboard Replacement, Keyboard: 步骤 1 中的图像 1,1
    • Flip device over so that the battery is farthest from you.
    • Identify the switch on the upper left corner and push it left to be in "unlocked" position.
  2. Acer Aspire One A150-1570 Keyboard Replacement: 步骤 2 中的图像 1,2 Acer Aspire One A150-1570 Keyboard Replacement: 步骤 2 中的图像 2,2
    • Identify the latch on the upper right hand corner. Drag and hold the latch to the right.
    • Pull the battery out.
  3. Acer Aspire One A150-1570 Keyboard Replacement: 步骤 3 中的图像 1,2 Acer Aspire One A150-1570 Keyboard Replacement: 步骤 3 中的图像 2,2
    • Now flip device back over to show the keyboard.
    • Locate the three tabs at the top of the keyboard.
  4. Acer Aspire One A150-1570 Keyboard Replacement: 步骤 4 中的图像 1,3 Acer Aspire One A150-1570 Keyboard Replacement: 步骤 4 中的图像 2,3 Acer Aspire One A150-1570 Keyboard Replacement: 步骤 4 中的图像 3,3
    • Start on the top-right and use the spudger to push off the tab from the keyboard.
    • Move to the middle tab while still holding the right side up so the tab doesn't fall back into place.
    • Continue to hold up keyboard while disconnecting the last tab.
    • DO NOT lift keyboard yet. This will be addressed in the next step.
  5. Acer Aspire One A150-1570 Keyboard Replacement: 步骤 5 中的图像 1,3 Acer Aspire One A150-1570 Keyboard Replacement: 步骤 5 中的图像 2,3 Acer Aspire One A150-1570 Keyboard Replacement: 步骤 5 中的图像 3,3
    • Here you can see that the keyboard is still attached to the device.
    • Use the Spudger to lift the ZIF (Zero Insertion Force) to release the keyboard ribbon.
    • Once tab is lifted, the keyboard ribbon should come right out.
结论
2等其他人完成本指南。
Blue
于10/10/16注册
124 声望
撰写一个指南
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 3
总计 441
