跳转到主内容
Acer Aspire One 751h-1948 Display Replacement
你所需要的
  1. Acer Aspire One 751h-1948 Display Replacement, Battery: 步骤 1 中的图像 1,1
    • Close the laptop and flip it over to view the back of the laptop.
  2. Acer Aspire One 751h-1948 Display Replacement: 步骤 2 中的图像 1,3 Acer Aspire One 751h-1948 Display Replacement: 步骤 2 中的图像 2,3 Acer Aspire One 751h-1948 Display Replacement: 步骤 2 中的图像 3,3
    • Unlock the right side of the battery by sliding the battery lock to the right. Then slide the left lock to the left and remove the battery.
  3. Acer Aspire One 751h-1948 Display Replacement, Network Card: 步骤 3 中的图像 1,2 Acer Aspire One 751h-1948 Display Replacement, Network Card: 步骤 3 中的图像 2,2
    • Unscrew the two Phillips #0 (M2-L2.5 mm) holding down the network card panel.
    • These screws don't come all the way out.
  4. Acer Aspire One 751h-1948 Display Replacement: 步骤 4 中的图像 1,3 Acer Aspire One 751h-1948 Display Replacement: 步骤 4 中的图像 2,3 Acer Aspire One 751h-1948 Display Replacement: 步骤 4 中的图像 3,3
    • Unplug the two connecting cables by lifting them up. They should unclip easily.
  5. Acer Aspire One 751h-1948 Display Replacement: 步骤 5 中的图像 1,3 Acer Aspire One 751h-1948 Display Replacement: 步骤 5 中的图像 2,3 Acer Aspire One 751h-1948 Display Replacement: 步骤 5 中的图像 3,3
    • Remove the screw Phillips #0 (M2-L3 mm) holding down the network card. Pull out the card.
  6. Acer Aspire One 751h-1948 Display Replacement, Hard Drive: 步骤 6 中的图像 1,1
    • Unscrew the Phillips 0# (M2 L2.5 mm) screw and remove the cover panel.
    • These screws will not come out all the way.
  7. Acer Aspire One 751h-1948 Display Replacement: 步骤 7 中的图像 1,3 Acer Aspire One 751h-1948 Display Replacement: 步骤 7 中的图像 2,3 Acer Aspire One 751h-1948 Display Replacement: 步骤 7 中的图像 3,3
    • Remove the hard drive by sliding it to the left and pull it out.
  8. Acer Aspire One 751h-1948 Display Replacement: 步骤 8 中的图像 1,2 Acer Aspire One 751h-1948 Display Replacement: 步骤 8 中的图像 2,2
    • Unscrew the Phillips #0 (M2-L2.5 mm) screws.
  9. Acer Aspire One 751h-1948 Display Replacement, Keyboard: 步骤 9 中的图像 1,3 Acer Aspire One 751h-1948 Display Replacement, Keyboard: 步骤 9 中的图像 2,3 Acer Aspire One 751h-1948 Display Replacement, Keyboard: 步骤 9 中的图像 3,3
    • Use the plastic opening tool to push in each of the four clips and carefully lift the keyboard.
    • Don't lift the keyboard completely so that you don't damage the ribbon cable underneath.
  10. Acer Aspire One 751h-1948 Display Replacement: 步骤 10 中的图像 1,2 Acer Aspire One 751h-1948 Display Replacement: 步骤 10 中的图像 2,2
    • When you remove the keyboard, be careful not to damage the ribbon cable that attaches it to the motherboard.
    • Unplug the ribbon cable by gently lifting the black tab up. Then remove the cable.
  11. Acer Aspire One 751h-1948 Display Replacement, Display: 步骤 11 中的图像 1,3 Acer Aspire One 751h-1948 Display Replacement, Display: 步骤 11 中的图像 2,3 Acer Aspire One 751h-1948 Display Replacement, Display: 步骤 11 中的图像 3,3
    • Unplug the SCD cable
  12. Acer Aspire One 751h-1948 Display Replacement: 步骤 12 中的图像 1,2 Acer Aspire One 751h-1948 Display Replacement: 步骤 12 中的图像 2,2
    • Use the spudger to remove all rubber pads covering the screws for the upper casing.
    • Then unscrew all the Phillips #0 (M2-L5 mm) screws under rubber pads.
  13. Acer Aspire One 751h-1948 Display Replacement: 步骤 13 中的图像 1,3 Acer Aspire One 751h-1948 Display Replacement: 步骤 13 中的图像 2,3 Acer Aspire One 751h-1948 Display Replacement: 步骤 13 中的图像 3,3
    • Separate the upper casing from the display.
  14. Acer Aspire One 751h-1948 Display Replacement: 步骤 14 中的图像 1,3 Acer Aspire One 751h-1948 Display Replacement: 步骤 14 中的图像 2,3 Acer Aspire One 751h-1948 Display Replacement: 步骤 14 中的图像 3,3
    • Unscrew all the Phillips 0# (M2-L2.5 mm) on each side of the display.
  15. Acer Aspire One 751h-1948 Display Replacement: 步骤 15 中的图像 1,1
    • Separate the screen from the metal frame that secures it to the upper casing and remove the screen.
    • Be careful, the display is very sensitive.
结论
Chris Bolton
于03/22/17注册
434 声望
创作了4篇指南
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 6
总计 340
