跳转到主内容
Acer Aspire One 725-0845 Hard Drive Replacement
你所需要的
  1. Acer Aspire One 725-0845 Hard Drive Replacement, Battery: 步骤 1 中的图像 1,1
    • Ensure the device is powered off by holding down the power button on the top left-hand side.
    • On a flat, level surface, flip the device over so that the back-plate is accessible.
  2. Acer Aspire One 725-0845 Hard Drive Replacement: 步骤 2 中的图像 1,3 Acer Aspire One 725-0845 Hard Drive Replacement: 步骤 2 中的图像 2,3 Acer Aspire One 725-0845 Hard Drive Replacement: 步骤 2 中的图像 3,3
    • Using a spudger or any fine-pointed tool, push the release slide away from the center of the device.
    • Simultaneously pull the battery out and away from the device.
  3. Acer Aspire One 725-0845 Hard Drive Replacement, Back Plate: 步骤 3 中的图像 1,3 Acer Aspire One 725-0845 Hard Drive Replacement, Back Plate: 步骤 3 中的图像 2,3 Acer Aspire One 725-0845 Hard Drive Replacement, Back Plate: 步骤 3 中的图像 3,3
    • Using the JIS J1 Screwdriver Bit and Driver, remove the center screw (7.0 mm) from the back-plate.
    • Using your hands, slide the back-plate away from the center of the device and remove.
  4. Acer Aspire One 725-0845 Hard Drive Replacement, Hard Drive: 步骤 4 中的图像 1,2 Acer Aspire One 725-0845 Hard Drive Replacement, Hard Drive: 步骤 4 中的图像 2,2
    • Using the JIS J1 Screwdriver Bit and Driver, remove the two screws (9.0 mm) from the outward side of the hard drive.
  5. Acer Aspire One 725-0845 Hard Drive Replacement: 步骤 5 中的图像 1,1
    • Using your hand, slide the hard drive away from the center of the device until it disconnects from the motherboard.
    • Carefully lift the outward side of the hard drive and place the drive on a clean, non-magnetic surface.
结论
2等其他人完成本指南。
Jose Souto
于02/15/17注册
337 声望
创作了3篇指南
团队
USF Tampa, Team 8-3, Eyestone Spring 2017 USF Tampa, Team 8-3, Eyestone Spring 2017 的会员
USFT-EYESTONE-S17S8G3
4 名成员
创作了16篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 17
总计 1,392
