当前版本的文档还未经巡查,您可以查看最新的已查核版本。
这个步骤还没有翻译 帮忙翻译一下
Power down the netbook by pressing the power button on the top left corner.
Close the netbook and flip it over so that the back is facing up.
Slide the button below the battery to the right while simultaneously pulling the battery out.
If necessary, remove the old battery and replace it with a new one.
Check the thin grooves on the side of the battery entry and line the replacement battery up to the grooves.
Remove the black rubber clips from the bottom right and left of the netbook screen.
Remove the screws under the black caps.
Slowly separate the screen casing from the screen.
Potential for device damage: Be careful when detaching the screen casing from the screen. If not done slowly, it can break.
Remove the screws located on the four corners of the screen.
Remove the two bottom screws.
Taking out these screws will allow you to remove the screen from its attachment.
On the bottom left of the screen there is a cord attached. Remove the tape that is attached to the screen.
On the green board, remove the two screws.
Remove the board.
取消:我没有完成这个指南。
4等其他人完成本指南。
与3其他贡献者
于10/25/15注册
818 声望
创作了5篇指南
徽章: 13
+ 10更多徽章
UMASSD-GULBRANDSEN-F15S5G6
3 名成员
创作了10篇指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 8
总计 3,292
