跳转到主内容
Acer Aspire One 722 RAM Replacement
你所需要的
  1. Acer Aspire One 722 RAM Replacement, Battery: 步骤 1 中的图像 1,1
    • Power down the netbook by pressing the power button on the top left corner.
  2. Acer Aspire One 722 RAM Replacement: 步骤 2 中的图像 1,1
    • Close the netbook and flip it over so that the back is facing up.
  3. Acer Aspire One 722 RAM Replacement: 步骤 3 中的图像 1,1
    • Slide the button below the battery to the right while simultaneously pulling the battery out.
  4. Acer Aspire One 722 RAM Replacement: 步骤 4 中的图像 1,2 Acer Aspire One 722 RAM Replacement: 步骤 4 中的图像 2,2
    • If necessary, remove the old battery and replace it with a new one.
  5. Acer Aspire One 722 RAM Replacement: 步骤 5 中的图像 1,1
    • Check the thin grooves on the side of the battery entry and line the replacement battery up to the grooves.
  6. Acer Aspire One 722 RAM Replacement, RAM: 步骤 6 中的图像 1,1
    • Remove the screw at the bottom of the laptop.
  7. Acer Aspire One 722 RAM Replacement: 步骤 7 中的图像 1,1
    • Take the plastic backing plate off.
  8. Acer Aspire One 722 RAM Replacement: 步骤 8 中的图像 1,1
    • Unclip the two metal braces that hold the RAM in place by pushing the metal clips outwards away from the RAM itself.
    • The RAM should pop up.
  9. Acer Aspire One 722 RAM Replacement: 步骤 9 中的图像 1,1
    • Grab the RAM and remove slowly.
  10. Acer Aspire One 722 RAM Replacement: 步骤 10 中的图像 1,1
    • Take the replacement RAM stick and line up the the grooves on the RAM to the grooves on the netbook so that they will fit in flush.
  11. Acer Aspire One 722 RAM Replacement: 步骤 11 中的图像 1,1
    • Press down on the RAM stick and the metal clips will lock in to place.
结论
3等其他人完成本指南。
团队
UMass Dartmouth, Team 5-6, Gulbrandsen Fall 2015 UMass Dartmouth, Team 5-6, Gulbrandsen Fall 2015 的会员
UMASSD-GULBRANDSEN-F15S5G6
3 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 8
总计 1,997
