跳转到主内容
Acer Aspire One 722 Keyboard Keys and Battery Replacement
你所需要的
  1. Acer Aspire One 722 Keyboard Keys and Battery Replacement, Battery: 步骤 1 中的图像 1,1
    • Power down the netbook by pressing the power button on the top left corner.
  2. Acer Aspire One 722 Keyboard Keys and Battery Replacement: 步骤 2 中的图像 1,1
    • Close the netbook and flip it over so that the back is facing up.
  3. Acer Aspire One 722 Keyboard Keys and Battery Replacement: 步骤 3 中的图像 1,1
    • Slide the button below the battery to the right while simultaneously pulling the battery out.
  4. Acer Aspire One 722 Keyboard Keys and Battery Replacement: 步骤 4 中的图像 1,2 Acer Aspire One 722 Keyboard Keys and Battery Replacement: 步骤 4 中的图像 2,2
    • If necessary, remove the old battery and replace it with a new one.
  5. Acer Aspire One 722 Keyboard Keys and Battery Replacement: 步骤 5 中的图像 1,1
    • Check the thin grooves on the side of the battery entry and line the replacement battery up to the grooves.
  6. Acer Aspire One 722 Keyboard Keys and Battery Replacement, Keyboard Keys and Battery: 步骤 6 中的图像 1,1
    • Use the flat end of a spudger to pry off the keyboard key.
    • If the key is broken, just remove the broken key and press a new key down over the empty key area. If you need to repair the key, follow the steps below.
  7. Acer Aspire One 722 Keyboard Keys and Battery Replacement: 步骤 7 中的图像 1,2 Acer Aspire One 722 Keyboard Keys and Battery Replacement: 步骤 7 中的图像 2,2
    • Use a spudger to pry the upper portion on both sides of the mechanism until it pops off from the key socket.
  8. Acer Aspire One 722 Keyboard Keys and Battery Replacement: 步骤 8 中的图像 1,3 Acer Aspire One 722 Keyboard Keys and Battery Replacement: 步骤 8 中的图像 2,3 Acer Aspire One 722 Keyboard Keys and Battery Replacement: 步骤 8 中的图像 3,3
    • Take both pivoting pieces of the mechanism and put them together.
    • The smaller piece fits through the inner part of the larger piece and lays in the groove of the larger piece.
    • Once assembled, it should be entirely flat.
  9. Acer Aspire One 722 Keyboard Keys and Battery Replacement: 步骤 9 中的图像 1,1
    • Position the pivoting smaller piece of the key mechanism in the lower hooks of the key socket.
    • Slide your finger across the upper portion of the key mechanism so that it locks in place with the upper hooks of the key socket.
  10. Acer Aspire One 722 Keyboard Keys and Battery Replacement: 步骤 10 中的图像 1,1
    • Place the key on top of the empty key space and press it down firmly until the key locks in place.
结论
另外一个人完成了本指南。
团队
UMass Dartmouth, Team 5-6, Gulbrandsen Fall 2015 UMass Dartmouth, Team 5-6, Gulbrandsen Fall 2015 的会员
UMASSD-GULBRANDSEN-F15S5G6
3 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 8
过去 30 天: 26
总计 4,238
