跳转到主内容
Acer Aspire One 722 Battery Replacement
  1. Acer Aspire One 722 Battery Replacement, Battery: 步骤 1 中的图像 1,1
    • Power down the netbook by pressing the power button on the top left corner.
  2. Acer Aspire One 722 Battery Replacement: 步骤 2 中的图像 1,1
    • Close the netbook and flip it over so that the back is facing up.
  3. Acer Aspire One 722 Battery Replacement: 步骤 3 中的图像 1,1
    • Slide the button below the battery to the right while simultaneously pulling the battery out.
  4. Acer Aspire One 722 Battery Replacement: 步骤 4 中的图像 1,2 Acer Aspire One 722 Battery Replacement: 步骤 4 中的图像 2,2
    • If necessary, remove the old battery and replace it with a new one.
  5. Acer Aspire One 722 Battery Replacement: 步骤 5 中的图像 1,1
    • Check the thin grooves on the side of the battery entry and line the replacement battery up to the grooves.
结论
12等其他人完成本指南。
团队
UMass Dartmouth, Team 5-6, Gulbrandsen Fall 2015 UMass Dartmouth, Team 5-6, Gulbrandsen Fall 2015 的会员
UMASSD-GULBRANDSEN-F15S5G6
3 名成员
创作了10篇指南
4条评论
First rate easy to understand completed in less than a minute.many thanks
Alan Fowler - 回复
I find myself computer savvy. These steps jarred my memory. They were perfect.
scolan910 - 回复
Thank you, you are a hero of 2021.
Athirah siagian - 回复
Thank you. Simple, yes, but a little encouragement always helps.
Wade Stanfill - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 22
过去 30 天: 66
总计 12,267
