跳转到主内容
Acer Aspire One 532h-2806 Screen Replacement
你所需要的
  1. Acer Aspire One 532h-2806 Screen Replacement, Screen: 步骤 1 中的图像 1,2 Acer Aspire One 532h-2806 Screen Replacement, Screen: 步骤 1 中的图像 2,2
    • Turn the device off before beginning any replacements.
    • Locate the two circular black stickers at the bottom corners of the laptop screen.
    • Remove the stickers.
    • Two 6mm Phillips Screws should now be visible.
  2. Acer Aspire One 532h-2806 Screen Replacement: 步骤 2 中的图像 1,2 Acer Aspire One 532h-2806 Screen Replacement: 步骤 2 中的图像 2,2
    • Use a Phillips #0 Screwdriver to remove the two 6mm screws from the screen.
  3. Acer Aspire One 532h-2806 Screen Replacement: 步骤 3 中的图像 1,2 Acer Aspire One 532h-2806 Screen Replacement: 步骤 3 中的图像 2,2
    • Using the opener tool, remove the plastic cover, surrounding the screen.
    • It is normal to hear clicking sounds as the plastic cover is removed.
  4. Acer Aspire One 532h-2806 Screen Replacement: 步骤 4 中的图像 1,3 Acer Aspire One 532h-2806 Screen Replacement: 步骤 4 中的图像 2,3 Acer Aspire One 532h-2806 Screen Replacement: 步骤 4 中的图像 3,3
    • Remove the four 6mm Phillips screws surrounding the screen.
    • These are holding the screen in place. After the screws are removed, the screen should remove itself from the plastic outer cover.
  5. Acer Aspire One 532h-2806 Screen Replacement: 步骤 5 中的图像 1,1
    • Peel back the fuss cable from the outer laptop plastic cover.
    • Be careful, not to yank or rip the cable, it should gently peel back.
  6. Acer Aspire One 532h-2806 Screen Replacement: 步骤 6 中的图像 1,1
    • Locate the ZIF (zero insertion force) Cable.
    • Peel back any tape if necessary
    • Carefully unplug it.
    • Do not pull hard, it should remove itself easily.
  7. Acer Aspire One 532h-2806 Screen Replacement: 步骤 7 中的图像 1,2 Acer Aspire One 532h-2806 Screen Replacement: 步骤 7 中的图像 2,2
    • Remove the two 6mm screws on each side of the screen with a Phillips #0 screwdriver.
  8. Acer Aspire One 532h-2806 Screen Replacement: 步骤 8 中的图像 1,3 Acer Aspire One 532h-2806 Screen Replacement: 步骤 8 中的图像 2,3 Acer Aspire One 532h-2806 Screen Replacement: 步骤 8 中的图像 3,3
    • Remove the screen.
结论
2等其他人完成本指南。
Julie Paula
于01/12/17注册
527 声望
创作了4篇指南
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 5
总计 316
