跳转到主内容
Acer Aspire One 532h-2806 Keyboard Replacement
你所需要的
  1. Acer Aspire One 532h-2806 Keyboard Replacement, Keyboard: 步骤 1 中的图像 1,1
    • Make sure the laptop is turned off and the battery is removed.
    • Above the top row of the keys, locate three plastic latches.
  2. Acer Aspire One 532h-2806 Keyboard Replacement: 步骤 2 中的图像 1,1
    • Use the medal spudger to press each tab. The keyboard should release.
    • Slide the spudger, so that the tabs do not reset after pressing each one.
  3. Acer Aspire One 532h-2806 Keyboard Replacement: 步骤 3 中的图像 1,1
    • Gently lift the keyboard up.
    • The keyboard ribbon cable is still attached to the motherboard.
  4. Acer Aspire One 532h-2806 Keyboard Replacement: 步骤 4 中的图像 1,1
    • Carefully unplug the connector sticker on the back of the keyboard.
    • Be gentle, do not force it out.
  5. Acer Aspire One 532h-2806 Keyboard Replacement: 步骤 5 中的图像 1,1
    • Remove the keyboard.
结论
Julie Paula
于01/12/17注册
527 声望
创作了4篇指南
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 7
总计 363
