跳转到主内容
Acer Aspire One 532h-2527 RAM Replacement
你所需要的
  1. Acer Aspire One 532h-2527 RAM Replacement, Battery: 步骤 1 中的图像 1,1
    • Press the power button to turn off the netbook.
  2. Acer Aspire One 532h-2527 RAM Replacement: 步骤 2 中的图像 1,1
    • Place the netbook bottom-side-up on a flat surface.
    • Locate the unlock latch on the top right corner of the back.
  3. Acer Aspire One 532h-2527 RAM Replacement: 步骤 3 中的图像 1,1
    • To unlock the battery, slide the lock latch in the direction indicated by the unlocking icon. You should see the orange indicator which means that the latch is unlocked.
  4. Acer Aspire One 532h-2527 RAM Replacement: 步骤 4 中的图像 1,3 Acer Aspire One 532h-2527 RAM Replacement: 步骤 4 中的图像 2,3 Acer Aspire One 532h-2527 RAM Replacement: 步骤 4 中的图像 3,3
    • On the opposite side, slide and hold the release latch.
    • Gently slide the battery out.
  5. Acer Aspire One 532h-2527 RAM Replacement, RAM: 步骤 5 中的图像 1,1
    • Use the #0 Phillips Screw bit with the Screwdriver to remove the single 6mm Phillips screw from the small back plate.
  6. Acer Aspire One 532h-2527 RAM Replacement: 步骤 6 中的图像 1,1
    • Use the plastic opening tool on the recessed notch at the bottom of the small plate to gently lift the plate up
  7. Acer Aspire One 532h-2527 RAM Replacement: 步骤 7 中的图像 1,2 Acer Aspire One 532h-2527 RAM Replacement: 步骤 7 中的图像 2,2
    • Once the plate becomes unhinged, gently rotate the plate to take it of of the device.
  8. Acer Aspire One 532h-2527 RAM Replacement: 步骤 8 中的图像 1,2 Acer Aspire One 532h-2527 RAM Replacement: 步骤 8 中的图像 2,2
    • Using two fingers, gently spread the latches on the sides of the RAM card until the RAM card props up.
  9. Acer Aspire One 532h-2527 RAM Replacement: 步骤 9 中的图像 1,2 Acer Aspire One 532h-2527 RAM Replacement: 步骤 9 中的图像 2,2
    • Once the RAM card is propped up, carefully pull it out of its port.
结论
另外一个人完成了本指南。
Jair Burgos
于09/15/16注册
425 声望
创作了3篇指南
团队
USF Tampa, Team 11-6, Blackwell Fall 2016 USF Tampa, Team 11-6, Blackwell Fall 2016 的会员
USFT-BLACKWELL-F16S11G6
3 名成员
创作了12篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 8
过去 30 天: 13
总计 682
