跳转到主内容
Acer Aspire One 532h-2527 Keyboard Replacement
你所需要的
  1. Acer Aspire One 532h-2527 Keyboard Replacement, Battery: 步骤 1 中的图像 1,1
    • Press the power button to turn off the netbook.
  2. Acer Aspire One 532h-2527 Keyboard Replacement: 步骤 2 中的图像 1,1
    • Place the netbook bottom-side-up on a flat surface.
    • Locate the unlock latch on the top right corner of the back.
  3. Acer Aspire One 532h-2527 Keyboard Replacement: 步骤 3 中的图像 1,1
    • To unlock the battery, slide the lock latch in the direction indicated by the unlocking icon. You should see the orange indicator which means that the latch is unlocked.
  4. Acer Aspire One 532h-2527 Keyboard Replacement: 步骤 4 中的图像 1,3 Acer Aspire One 532h-2527 Keyboard Replacement: 步骤 4 中的图像 2,3 Acer Aspire One 532h-2527 Keyboard Replacement: 步骤 4 中的图像 3,3
    • On the opposite side, slide and hold the release latch.
    • Gently slide the battery out.
  5. Acer Aspire One 532h-2527 Keyboard Replacement, Keyboard: 步骤 5 中的图像 1,1
    • Locate the three latches along the top crevice along the top rows of keys and the plastic boarder.
  6. Acer Aspire One 532h-2527 Keyboard Replacement: 步骤 6 中的图像 1,3 Acer Aspire One 532h-2527 Keyboard Replacement: 步骤 6 中的图像 2,3 Acer Aspire One 532h-2527 Keyboard Replacement: 步骤 6 中的图像 3,3
    • Using the metal spudger, gently pry each tab releasing the keyboard. Make sure as you move to each new one that the previous one does not reset itself.
  7. Acer Aspire One 532h-2527 Keyboard Replacement: 步骤 7 中的图像 1,1
    • Check for tabs on the side of the keyboard.
    • If there are no tabs lift the top of the keyboard.
  8. Acer Aspire One 532h-2527 Keyboard Replacement: 步骤 8 中的图像 1,3 Acer Aspire One 532h-2527 Keyboard Replacement: 步骤 8 中的图像 2,3 Acer Aspire One 532h-2527 Keyboard Replacement: 步骤 8 中的图像 3,3
    • Locate the sticker-like connecter on the back of the keyboard. Carefully unplug it.
  9. Acer Aspire One 532h-2527 Keyboard Replacement: 步骤 9 中的图像 1,2 Acer Aspire One 532h-2527 Keyboard Replacement: 步骤 9 中的图像 2,2
    • Remove keyboard.
结论
3等其他人完成本指南。
Jair Burgos
于09/15/16注册
425 声望
创作了3篇指南
团队
USF Tampa, Team 11-6, Blackwell Fall 2016 USF Tampa, Team 11-6, Blackwell Fall 2016 的会员
USFT-BLACKWELL-F16S11G6
3 名成员
创作了12篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 5
总计 706
