跳转到主内容
Acer Aspire M5-583P-9688 Hard Drive Replacement
你所需要的
  1. Acer Aspire M5-583P-9688 Hard Drive Replacement, Hard Drive: 步骤 1 中的图像 1,1
    • Remove the 18 marked screws (2.12 mm) using a Phillips #1 head screwdriver.
  2. Acer Aspire M5-583P-9688 Hard Drive Replacement: 步骤 2 中的图像 1,2 Acer Aspire M5-583P-9688 Hard Drive Replacement: 步骤 2 中的图像 2,2
    • Use the spudger to slowly work your way around the perimeter starting at the marked location to pop the bottom cover off.
  3. Acer Aspire M5-583P-9688 Hard Drive Replacement: 步骤 3 中的图像 1,2 Acer Aspire M5-583P-9688 Hard Drive Replacement: 步骤 3 中的图像 2,2
    • This particular laptop does not have a hard drive. The red rectangle is where your hard drive will be.
    • To remove the hard drive, carefully take it out of the brackets holding it in place. Once you have it out of the brackets, remove the connector from the hard drive.
结论
3等其他人完成本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 19
总计 1,586
