跳转到主内容
Acer Aspire M5-583P-6423 Battery Replacement
你所需要的
  1. Acer Aspire M5-583P-6423 Battery Replacement, Battery: 步骤 1 中的图像 1,3 Acer Aspire M5-583P-6423 Battery Replacement, Battery: 步骤 1 中的图像 2,3 Acer Aspire M5-583P-6423 Battery Replacement, Battery: 步骤 1 中的图像 3,3
    • Turn the computer off and close it. Disconnect the charging cable from the laptop and place the laptop upside down.
    • Remove seventeen M2.5x8mm screws on the back cover of the laptop with the Phillips #00 screwdriver.
  2. Acer Aspire M5-583P-6423 Battery Replacement: 步骤 2 中的图像 1,2 Acer Aspire M5-583P-6423 Battery Replacement: 步骤 2 中的图像 2,2
    • Push the back cover up from each side using the iFixit opening tool.
    • You’ll hear a popping sound as you lift the back cover.
    • Once the back cover is separated, you’ll see all the internal components of the laptop.
  3. Acer Aspire M5-583P-6423 Battery Replacement: 步骤 3 中的图像 1,2 Acer Aspire M5-583P-6423 Battery Replacement: 步骤 3 中的图像 2,2
    • Pull the rainbow cord out by using the iFixit opening tool on each side of its connecting slot.
    • This step can be done by using your fingers, but its highly recommended to use the iFixit removal tool instead.
  4. Acer Aspire M5-583P-6423 Battery Replacement: 步骤 4 中的图像 1,1
    • Remove the M2.5 x 3mm screw that holds down the battery using the Phillips #00 screwdriver.
  5. Acer Aspire M5-583P-6423 Battery Replacement: 步骤 5 中的图像 1,1
    • Lift the battery up from its edges and pull back slightly towards the hinges to remove the battery.
    • The battery is now detached from the laptop and can be set aside.
结论
2等其他人完成本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 16
总计 804
