简介
This guide will help you remove your RAM so it can be replaced. Replacing your RAM may improve the amount of background memory on your laptop. With this, your laptop will run faster, allow more tabs to be opened, and increase memory. You may need a new RAM if your laptop is slow in loading new pages, and becomes slower with multiple tabs.
你所需要的
Place the laptop face down on a flat, clean surface.
Remove all twenty-seven 7 mm screws on the back cover of the laptop with a Phillips #0 screwdriver. Screws are circled in red on the diagram.
另外一个人完成了本指南。
