跳转到主内容
Acer Aspire ES1-711-P1UV Hard Drive Replacement
你所需要的
  1. Acer Aspire ES1-711-P1UV Hard Drive Replacement, Battery: 步骤 1 中的图像 1,1
    • Place the laptop face down on a flat, clean surface.
    • Remove all twenty-seven 7 mm screws on the back cover of the laptop with a Phillips #0 screwdriver. Screws are circled in red on the diagram.
  2. Acer Aspire ES1-711-P1UV Hard Drive Replacement: 步骤 2 中的图像 1,1
    • Use the iFixit opening tool to pry open the four corners of the back cover of the laptop. You may need to use your hands to fully remove the cover.
    • Be sure to evenly apply pressure when removing the back cover.
  3. Acer Aspire ES1-711-P1UV Hard Drive Replacement: 步骤 3 中的图像 1,1
    • Remove the two 5 mm screws located on either side of the battery.
  4. Acer Aspire ES1-711-P1UV Hard Drive Replacement: 步骤 4 中的图像 1,1
    • Disconnect the colored bundled cable connectors from the motherboard. To do this, pull on the wires to disconnect the cable and remove the battery.
  5. Acer Aspire ES1-711-P1UV Hard Drive Replacement, Hard Drive: 步骤 5 中的图像 1,1
    • Remove the four 4.5 mm screws that hold the hard drive in place.
  6. Acer Aspire ES1-711-P1UV Hard Drive Replacement: 步骤 6 中的图像 1,2 Acer Aspire ES1-711-P1UV Hard Drive Replacement: 步骤 6 中的图像 2,2
    • Remove the tabs holding the hard drive in place.
    • Remove the hard drive.
结论
3等其他人完成本指南。
Lindsay O'Shea
于03/22/18注册
414 声望
创作了3篇指南
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 6
过去 30 天: 23
总计 2,508
