跳转到主内容
Acer Aspire ES1-711-P1UV Battery Replacement
你所需要的
  1. Acer Aspire ES1-711-P1UV Battery Replacement, Battery: 步骤 1 中的图像 1,1
    • Place the laptop face down on a flat, clean surface.
    • Remove all twenty-seven 7 mm screws on the back cover of the laptop with a Phillips #0 screwdriver. Screws are circled in red on the diagram.
  2. Acer Aspire ES1-711-P1UV Battery Replacement: 步骤 2 中的图像 1,1
    • Use the iFixit opening tool to pry open the four corners of the back cover of the laptop. You may need to use your hands to fully remove the cover.
    • Be sure to evenly apply pressure when removing the back cover.
  3. Acer Aspire ES1-711-P1UV Battery Replacement: 步骤 3 中的图像 1,1
    • Remove the two 5 mm screws located on either side of the battery.
  4. Acer Aspire ES1-711-P1UV Battery Replacement: 步骤 4 中的图像 1,1
    • Disconnect the colored bundled cable connectors from the motherboard. To do this, pull on the wires to disconnect the cable and remove the battery.
结论
4等其他人完成本指南。
Lindsay O'Shea
于03/22/18注册
414 声望
创作了3篇指南
团队
2条评论
Excellent instructions, Thxz.
jmarquez_cruz - 回复
Wuen i reassemble my laptop doesnt power on…
mk Bane - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 9
过去 30 天: 29
总计 4,113
