简介
You may need to replace the RAM on your Acer Aspire ES1-512-C80E if you experience problems regarding the device’s power. To do this, you will need Phillip’s #00/#000 screwdrivers, and a spudger. Additionally, you will need a replacement RAM. To access the RAM, the back cover of the device will need to be removed. The process of replacing the RAM should take between 10-20 minutes.
你所需要的
Place the device upside down on a flat surface.
Using a Phillips #00 screwdriver, remove all nineteen 1.2mm screws that secure the bottom cover of the device.
Using a Phillips #00 screwdriver, remove the four 1.2mm screws from the keyboard.
Using a spudger, go around the edges and pry off the keyboard.
Using a Phillips #000 screwdriver, remove the five 1.2mm screws that hold the hard drive in place.
Once the four components are out of the device, the hard drive is ready to be removed.
To remove the hard drive, unplug it from the motherboard.
另外一个人完成了本指南。
