跳转到主内容
Acer Aspire ES1-512-C80E Keyboard Replacement
你所需要的
  1. Acer Aspire ES1-512-C80E Keyboard Replacement, Back Cover: 步骤 1 中的图像 1,1
    • Place the device upside down on a flat surface.
    • Using a Phillips #00 screwdriver, remove all nineteen 1.2mm screws that secure the bottom cover of the device.
  2. Acer Aspire ES1-512-C80E Keyboard Replacement: 步骤 2 中的图像 1,3 Acer Aspire ES1-512-C80E Keyboard Replacement: 步骤 2 中的图像 2,3 Acer Aspire ES1-512-C80E Keyboard Replacement: 步骤 2 中的图像 3,3
    • Pry around the edges with a spudger to remove the back cover.
    • The two hinges on the back require additional force to be popped open.
  3. Acer Aspire ES1-512-C80E Keyboard Replacement, Keyboard: 步骤 3 中的图像 1,3 Acer Aspire ES1-512-C80E Keyboard Replacement, Keyboard: 步骤 3 中的图像 2,3 Acer Aspire ES1-512-C80E Keyboard Replacement, Keyboard: 步骤 3 中的图像 3,3
    • The keyboard is the silver piece located by itself on the upper half of the laptop.
    • Using a Phillips #00 screwdriver, remove the four 1.2mm screws from the keyboard.
    • Using a spudger, go around the edges and pry off the keyboard.
    • All black clips will have to be removed before the keyboard can be removed.
  4. Acer Aspire ES1-512-C80E Keyboard Replacement: 步骤 4 中的图像 1,3 Acer Aspire ES1-512-C80E Keyboard Replacement: 步骤 4 中的图像 2,3 Acer Aspire ES1-512-C80E Keyboard Replacement: 步骤 4 中的图像 3,3
    • Remove the ribbon cable connection from the keyboard.
    • Peel back the two pieces of tape to separate the keyboard.
    • Remove the keyboard from under the plastic covering.
    • Remove the silver plate back cover of the keyboard from the bottom base.
  5. Acer Aspire ES1-512-C80E Keyboard Replacement: 步骤 5 中的图像 1,2 Acer Aspire ES1-512-C80E Keyboard Replacement: 步骤 5 中的图像 2,2
    • Remove the large silver plate from the keyboard.
    • You can not remove the silver backing with the attached wire from the back of the keyboard.
  6. Acer Aspire ES1-512-C80E Keyboard Replacement: 步骤 6 中的图像 1,1
    • The keyboard is removed and ready to be replaced.
结论
另外一个人完成了本指南。
团队
UMass Dartmouth, Team S2-G8, Barthe Fall 2019 UMass Dartmouth, Team S2-G8, Barthe Fall 2019 的会员
UMASSD-BARTHE-F19S2G8
3 名成员
创作了7篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 3
过去 30 天: 20
总计 1,187
