简介
You may need to replace the hard drive in your Acer Aspire ES1-512-C80E if you experience problems regarding the device’s storage. To do this, you will need Phillip’s #00/#000 screwdrivers, and a spudger. Additionally, you will need a replacement hard drive. To access the hard drive, the back cover of the device will need to be removed. The process of replacing the battery should take between 15-25 minutes.
你所需要的
Place the device upside down on a flat surface.
Using a Phillips #00 screwdriver, remove all nineteen 1.2mm screws that secure the bottom cover of the device.
Using a Phillips #000 screwdriver, remove the five 1.2mm screws that hold the hard drive in place.
Once the four components are out of the device, the hard drive is ready to be removed.
To remove the hard drive, unplug it from the motherboard.
一条评论
Not the best instructions, YouTube worked better for this laptop.
This wasn’t that difficult for me, you of course don’t need to replace the keyboard, or take out the motherboard.
After unscrewing the base and prying open the case, the keyboard side can be lifted out (Two cables need to disconnected). After unscrewing the 1 screw at the back of the HDD, I was able to slide it slowly out.
After removing the bracket from the HDD to my new SSD I slid the new drive in, screwed the bracket back down and closed up.
This should be a 4 step guide and down as moderate
Alex Culff - 回复
