视频概述
  1. Grab a spudger and work your way around the outer edge of the screen Lean the screen all the way back to remove the plastic frame from the hinges at the bottom Lean the screen all the way back to remove the plastic frame from the hinges at the bottom
    • Grab a spudger and work your way around the outer edge of the screen
    • Lean the screen all the way back to remove the plastic frame from the hinges at the bottom
  2. Unscrew the 4 screws around the edge of the screen Lean the screen all the way forward on to the keyboard
    • Unscrew the 4 screws around the edge of the screen
    • Lean the screen all the way forward on to the keyboard
  3. 所有超过US$100或包含 Pro Tech工具包的订单免费送货!
    浏览我们的商店
  4. Peal up the sticky tape next to the screen connector Pull the connector down carefully away from the screen and disconnect it
    • Peal up the sticky tape next to the screen connector
    • Pull the connector down carefully away from the screen and disconnect it
  5. connect the new screen and screw back in place Turn on the screen to test before putting the screen frame back on Tilt the screen all the way back and push the frame back on hinges 1st.
    • connect the new screen and screw back in place
    • Turn on the screen to test before putting the screen frame back on
    • Tilt the screen all the way back and push the frame back on hinges 1st.
    • Finally lean the laptop on its edge and clip the back on the hinges back in place.
终点
Nick Myers
于2018年04月15日注册
383 信誉积分
创作了2篇指南
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 2
过去的30天: 8
总计 81
