你所需要的
Unscrew all 16 screws holding the back panel.
Open the HDD, SSD and RAM cover and unscrew all visible screws that hold the panel. Now is a good idea to upgrade those parts if you want.
Use a prying tool to separate the top and bottom pieces.
Disconnect all visible connectors, starting with the battery (Yellow), they the other ones (Blue). After that remove the screws attaching the motherboard to the panel.
After that remove the black protective film, without damaging it. Now the keyboard should be revealed.
Remove the screws that hold the display hinges and detach the display.
Use a soldering iron with a big tip, to melt the plastic rivets that hold the metal case for the keyboard.
Use a prying tool the remove the metal case.
Remove the old keyboard, place the new one and dont forget to place the metal case on top of it.
