跳转到主内容
Acer Aspire E5-573G Fan Replacement
你所需要的
  1. Acer Aspire E5-573G Fan  Replacement, Fan: 步骤 1 中的图像 1,2 Acer Aspire E5-573G Fan  Replacement, Fan: 步骤 1 中的图像 2,2
    • Remove the seventeen 5 mm screws from the back cover using a Phillips #00 screwdriver.
    • Be sure to unplug and power down your computer before starting any work.
  2. Acer Aspire E5-573G Fan  Replacement: 步骤 2 中的图像 1,2 Acer Aspire E5-573G Fan  Replacement: 步骤 2 中的图像 2,2
    • Remove the CD drive located on the side of the laptop.
  3. Acer Aspire E5-573G Fan  Replacement: 步骤 3 中的图像 1,1
    • Remove the three 2 mm screws from the disc drive bay using a Phillips #00 screwdriver.
  4. Acer Aspire E5-573G Fan  Replacement: 步骤 4 中的图像 1,3 Acer Aspire E5-573G Fan  Replacement: 步骤 4 中的图像 2,3 Acer Aspire E5-573G Fan  Replacement: 步骤 4 中的图像 3,3
    • Use the spudger to pry open the back cover by sliding it along the sides.
    • Slowly lift the cover upwards.
    • Be gentle while removing the case as it is very thin and might break easily.
  5. Acer Aspire E5-573G Fan  Replacement: 步骤 5 中的图像 1,2 Acer Aspire E5-573G Fan  Replacement: 步骤 5 中的图像 2,2
    • Apply canned air or use a bellows to remove the dust on the motherboard.
    • Remove the two 2 mm screws holding the fan to the motherboard using Phillips #00 screwdriver.
    • Be gentle unscrewing both screws as the motherboard can get damaged with extra force.
  6. Acer Aspire E5-573G Fan  Replacement: 步骤 6 中的图像 1,3 Acer Aspire E5-573G Fan  Replacement: 步骤 6 中的图像 2,3 Acer Aspire E5-573G Fan  Replacement: 步骤 6 中的图像 3,3
    • Lift out the fan and detach the fan cable from the motherboard.
    • When detaching the cable be careful not to pull the wires. Instead pull the white section that connects the fan to the motherboard.
结论
另外一个人完成了本指南。
Lara Mustafa
于01/08/21注册
133 声望
撰写一个指南
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 14
总计 808
