跳转到主内容
Acer Aspire E5-573G Battery Replacement
你所需要的
  1. Acer Aspire E5-573G Battery Replacement, Optical Drive: 步骤 1 中的图像 1,1
    • Ensure your device is OFF before beginning this procedure.
    • Unscrew the 5 mm Phillips head screw holding the drive in place.
  2. Acer Aspire E5-573G Battery Replacement: 步骤 2 中的图像 1,1
    • Pull out the disk drive.
  3. Acer Aspire E5-573G Battery Replacement, Battery: 步骤 3 中的图像 1,1
    • Unscrew the seventeen 5 mm Phillips head screws from the bottom cover.
  4. Acer Aspire E5-573G Battery Replacement: 步骤 4 中的图像 1,1
    • Unscrew the three 2.5 mm Phillips head screws underneath the optical drive bay.
  5. Acer Aspire E5-573G Battery Replacement: 步骤 5 中的图像 1,1
    • Run a pick between the bottom cover and the device around the edge of the laptop and unclip the cover from the rest of the device.
  6. Acer Aspire E5-573G Battery Replacement: 步骤 6 中的图像 1,1
    • Lift the left side of the bottom cover, but do not completely remove the cover, as the speaker is cable is still connected and will be damaged.
    • Pull the speaker connector towards the fan to disconnect it from its socket on the motherboard.
  7. Acer Aspire E5-573G Battery Replacement: 步骤 7 中的图像 1,1
    • Pull the battery connector towards the battery to disconnect it from its socket on the motherboard.
    • Remove the battery.
结论
14等其他人完成本指南。
Alex Bahm
于01/18/18注册
2,226 声望
创作了6篇指南
团队
Cal Poly, Team S12-G5, Banghart Winter 2018 Cal Poly, Team S12-G5, Banghart Winter 2018 的会员
CPSU-BANGHART-W18S12G5
2 名成员
创作了15篇指南
一条评论
Where can i buy a battery replacement for my aspire e5-573g-59c3?
mfortich98 - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 12
过去 30 天: 75
总计 21,625
