跳转到主内容
Acer Aspire E5-571P-55TL Keyboard Replacement
你所需要的
  1. Acer Aspire E5-571P-55TL Keyboard Replacement, Battery: 步骤 1 中的图像 1,1
    • Make sure that laptop is turned off.
    • Turn the laptop upside down with the battery facing you.
  2. Acer Aspire E5-571P-55TL Keyboard Replacement: 步骤 2 中的图像 1,1
    • Place the Spudger into the battery lock and slide it to the left until you hear the battery unlock.
  3. Acer Aspire E5-571P-55TL Keyboard Replacement: 步骤 3 中的图像 1,2 Acer Aspire E5-571P-55TL Keyboard Replacement: 步骤 3 中的图像 2,2
    • Pull the battery towards you to remove it from the laptop.
  4. Acer Aspire E5-571P-55TL Keyboard Replacement, Keyboard: 步骤 4 中的图像 1,2 Acer Aspire E5-571P-55TL Keyboard Replacement, Keyboard: 步骤 4 中的图像 2,2
    • Using a Phillips #0 screwdriver, remove each of the eighteen 8 mm screws from the bottom of the laptop.
  5. Acer Aspire E5-571P-55TL Keyboard Replacement: 步骤 5 中的图像 1,3 Acer Aspire E5-571P-55TL Keyboard Replacement: 步骤 5 中的图像 2,3 Acer Aspire E5-571P-55TL Keyboard Replacement: 步骤 5 中的图像 3,3
    • Carefully place your fingers underneath the top of the keyboard just below the screen.
    • Pull upwards until you can hear the keyboard click out of place.
    • Continue around the entire laptop, carefully pulling the keyboard and palm rest assembly slightly from the frame to reveal the ribbon connectors.
    • Don't pull the keyboard off the frame yet because it's attached by ribbon connectors.
    • After the keyboard is detached, unplug each of the three ribbon cables and remove the keyboard and palm rest assembly.
结论
团队
UMass Dartmouth, Team B-1, Gurgel Spring 2022 UMass Dartmouth, Team B-1, Gurgel Spring 2022 的会员
UMASSD-GURGEL-S22SBG1
4 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 7
过去 30 天: 11
总计 175
