跳转到主内容
Acer Aspire E5-571 Hard Drive Replacement
你所需要的
  1. Acer Aspire E5-571 Hard Drive Replacement, Battery: 步骤 1 中的图像 1,1
    • Make sure the laptop is shut down.
    • Flip the laptop upside down. Rotate it so the battery faces you.
  2. Acer Aspire E5-571 Hard Drive Replacement: 步骤 2 中的图像 1,1
    • Place the pointed end of a spudger into the battery lock. Slide the battery lock to the left using the spudger. A "click" sound will accompany the release of the battery.
  3. Acer Aspire E5-571 Hard Drive Replacement: 步骤 3 中的图像 1,1
    • Pull the battery towards you to remove it from the laptop.
  4. Acer Aspire E5-571 Hard Drive Replacement, Keyboard: 步骤 4 中的图像 1,1
    • Remove all eighteen 8 mm screws with a Phillips #0 screwdriver.
  5. Acer Aspire E5-571 Hard Drive Replacement: 步骤 5 中的图像 1,3 Acer Aspire E5-571 Hard Drive Replacement: 步骤 5 中的图像 2,3 Acer Aspire E5-571 Hard Drive Replacement: 步骤 5 中的图像 3,3
    • Carefully pry apart the clips holding the keyboard in place by moving a metal spudger along the seam.
    • Be careful not to break the plastic clips. Do not remove the keyboard until told to do so.
  6. Acer Aspire E5-571 Hard Drive Replacement: 步骤 6 中的图像 1,2 Acer Aspire E5-571 Hard Drive Replacement: 步骤 6 中的图像 2,2
    • Carefully flip up the white hinge. Then, detach the three ZIF ribbons connected to the motherboard.
    • Remove the panel with the keyboard and the touchpad.
  7. Acer Aspire E5-571 Hard Drive Replacement, Hard Drive: 步骤 7 中的图像 1,1
    • Locate the hard drive in the metal casing.
  8. Acer Aspire E5-571 Hard Drive Replacement: 步骤 8 中的图像 1,1
    • Remove these two 4 mm Phillips #1 screws.
  9. Acer Aspire E5-571 Hard Drive Replacement: 步骤 9 中的图像 1,2 Acer Aspire E5-571 Hard Drive Replacement: 步骤 9 中的图像 2,2
    • Locate this ZIF ribbon and carefully flip the white top hinge up and bend the ribbon over to the right side.
  10. Acer Aspire E5-571 Hard Drive Replacement: 步骤 10 中的图像 1,2 Acer Aspire E5-571 Hard Drive Replacement: 步骤 10 中的图像 2,2
    • Slide the hard drive to the right and gently lift it off of the laptop.
  11. Acer Aspire E5-571 Hard Drive Replacement: 步骤 11 中的图像 1,2 Acer Aspire E5-571 Hard Drive Replacement: 步骤 11 中的图像 2,2
    • There is one screw on each side of the metal hard drive casing you remove.
    • Slide the hard drive out of the metal casing.
结论
42等其他人完成本指南。
daniel sawyer
于08/23/15注册
2,566 声望
创作了5篇指南
团队
USF Tampa, Team 4-2, Meier Fall 2015 USF Tampa, Team 4-2, Meier Fall 2015 的会员
USFT-MEIER-F15S4G2
3 名成员
创作了5篇指南
8条评论
You can't beat the internet when it comes to sorting out a problem.
Many thanks to the author of this guide, it really helped me out
Michael Lee - 回复
These are excellent clear instructions, well done and thank you
David Waterhouse - 回复
Great directions. With visual ades too...nice.
Thanks
Jackie Abbott - 回复
Thank you for the clear instructions, this is an excellent guide.
Toni-Marie Catchpaw - 回复
Very helpful guide. Thanks for that! Only thing missing was a warning about where the plastic clips were around the body to make it easier to pop those without breaking the plastic tabs on some of them. Even that isn’t all that important really.
Michael King - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 11
过去 30 天: 61
总计 44,002
