跳转到主内容
Acer Aspire E5-471-5456 USB Port Replacement
你所需要的
  1. Acer Aspire E5-471-5456 USB Port Replacement, Back Cover: 步骤 1 中的图像 1,2 Acer Aspire E5-471-5456 USB Port Replacement, Back Cover: 步骤 1 中的图像 2,2
    • Carefully place the closed computer on a flat surface, with it oriented screen down.
    • Now you need to use the Phillips #0 Screwdriver to remove all 17 of the M2.5X8 mm screws. Use the red circles on the diagram to help you locate these screws.
  2. Acer Aspire E5-471-5456 USB Port Replacement: 步骤 2 中的图像 1,2 Acer Aspire E5-471-5456 USB Port Replacement: 步骤 2 中的图像 2,2
    • Use an opening tool to gently pry open the case.
    • Take extreme care when removing the case to not get the case stuck on any of the ports. Make sure that to evenly open the case and not pry one side open before the other to avoid damage.
    • Slowly peel the cover off and make sure there are no wires or clips still connecting the two pieces together. These pieces are extremely fragile so it is vital to take your time and only use light pressure.
  3. Acer Aspire E5-471-5456 USB Port Replacement: 步骤 3 中的图像 1,1
    • Place cover and screws aside and you are now free to access the different components of this laptop.
  4. Acer Aspire E5-471-5456 USB Port Replacement, USB Port: 步骤 4 中的图像 1,2 Acer Aspire E5-471-5456 USB Port Replacement, USB Port: 步骤 4 中的图像 2,2
    • Locate the two USB ports in the bottom corner of the laptop.
    • Use a screwdriver to take out the M2X3 mm screw located in the orange circle. For an easier reassembly, take note that the USB port has a white arrow that indicates which  orange hole the screw should be returned to.
  5. Acer Aspire E5-471-5456 USB Port Replacement: 步骤 5 中的图像 1,2 Acer Aspire E5-471-5456 USB Port Replacement: 步骤 5 中的图像 2,2
    • Remove the cable (look for the one with a blue tag reading "USB") very carefully as it is fragile by using the opening tool.
  6. Acer Aspire E5-471-5456 USB Port Replacement: 步骤 6 中的图像 1,1
    • The USB ports should now be able to be removed from the laptop, carefully.
结论
2等其他人完成本指南。
Justin Saeidian
于09/26/17注册
273 声望
创作了2篇指南
团队
Cal Poly, Team S6-G4, Banghart Fall 2017 Cal Poly, Team S6-G4, Banghart Fall 2017 的会员
CPSU-BANGHART-F17S6G4
5 名成员
创作了6篇指南
一条评论
where can i purchase the port
Jermian Francis - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 18
总计 1,944
