简介
The function of a RAM, also known as system memory, temporarily carries software and files in current use. This physical memory is important in keeping your laptop running smoothly otherwise the laptop starts to run slow. This guide will help with the removal of the RAM cards.
你所需要的
Carefully place the closed computer on a flat surface, with it oriented screen down.
Now you need to use the Phillips #0 Screwdriver to remove all 17 of the M2.5X8 mm screws. Use the red circles on the diagram to help you locate these screws.
即将完成!
结论
