跳转到主内容
Acer Aspire E3-111-C0WA Hard Drive Replacement
你所需要的
  1. Acer Aspire E3-111-C0WA Hard Drive Replacement, Battery: 步骤 1 中的图像 1,2 Acer Aspire E3-111-C0WA Hard Drive Replacement, Battery: 步骤 1 中的图像 2,2
    • Remove the 13 indicated screws (6.2 mm) using a Phillips #1 screwdriver.
  2. Acer Aspire E3-111-C0WA Hard Drive Replacement: 步骤 2 中的图像 1,3 Acer Aspire E3-111-C0WA Hard Drive Replacement: 步骤 2 中的图像 2,3 Acer Aspire E3-111-C0WA Hard Drive Replacement: 步骤 2 中的图像 3,3
    • Insert your plastic opening tool between the bottom case and the rest of the laptop.
    • Using the plastic opening tool as a lever, apply downward pressure on the tool to lift the bottom up.
    • Make your way around the case with the tool, every so often applying downward pressure to lift the bottom up.
    • Lift the bottom off the laptop.
  3. Acer Aspire E3-111-C0WA Hard Drive Replacement: 步骤 3 中的图像 1,2 Acer Aspire E3-111-C0WA Hard Drive Replacement: 步骤 3 中的图像 2,2
    在这个步骤中使用的工具:
    Anti-Static Wrist Strap
    $7.95
    购买
    • Make sure you have properly grounded yourself to avoid potentially damaging any internal components by wearing the anti-static wrist strap and attaching the clip end to metal.
    • Press and hold the battery discharge button on the motherboard for 5 seconds to drain the battery.
  4. Acer Aspire E3-111-C0WA Hard Drive Replacement: 步骤 4 中的图像 1,3 Acer Aspire E3-111-C0WA Hard Drive Replacement: 步骤 4 中的图像 2,3 Acer Aspire E3-111-C0WA Hard Drive Replacement: 步骤 4 中的图像 3,3
    • Dislodge the battery's connector to the motherboard by using the plastic opening tool as a lever on the two small plastic tabs that stick out on either side of the connector.
  5. Acer Aspire E3-111-C0WA Hard Drive Replacement: 步骤 5 中的图像 1,2 Acer Aspire E3-111-C0WA Hard Drive Replacement: 步骤 5 中的图像 2,2
    • Unscrew the two 6.2 mm Phillips #1 head screws on either side of the battery as indicated.
  6. Acer Aspire E3-111-C0WA Hard Drive Replacement: 步骤 6 中的图像 1,2 Acer Aspire E3-111-C0WA Hard Drive Replacement: 步骤 6 中的图像 2,2
    • Lift the battery up and off the rest of the laptop.
  7. Acer Aspire E3-111-C0WA Hard Drive Replacement, Hard Drive: 步骤 7 中的图像 1,2 Acer Aspire E3-111-C0WA Hard Drive Replacement, Hard Drive: 步骤 7 中的图像 2,2
    • Holding the laptop in place, slide the hard drive horizontally out from the SATA connector.
结论
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 4
过去 30 天: 13
总计 598
