跳转到主内容
Acer Aspire E1-510-2500 RAM Card Replacement
你所需要的
  1. Acer Aspire E1-510-2500 RAM Card Replacement, Battery: 步骤 1 中的图像 1,1
    • Ensure that your laptop is completely switched off, and disconnected from the power source.
    • Flip the laptop so that the base of the laptop is facing up.
  2. Acer Aspire E1-510-2500 RAM Card Replacement: 步骤 2 中的图像 1,2 Acer Aspire E1-510-2500 RAM Card Replacement: 步骤 2 中的图像 2,2
    • Insert a spudger into the battery release latch.
    • Slide the battery release latch to the right, this will eject the battery for safe removal.
  3. Acer Aspire E1-510-2500 RAM Card Replacement: 步骤 3 中的图像 1,2 Acer Aspire E1-510-2500 RAM Card Replacement: 步骤 3 中的图像 2,2
    • Carefully slide the battery out of the battery's home.
  4. Acer Aspire E1-510-2500 RAM Card Replacement, RAM Card: 步骤 4 中的图像 1,2 Acer Aspire E1-510-2500 RAM Card Replacement, RAM Card: 步骤 4 中的图像 2,2
    • Using a Phillips 1 screwdriver, remove the 9 mm screw which secures the back panel.
  5. Acer Aspire E1-510-2500 RAM Card Replacement: 步骤 5 中的图像 1,2 Acer Aspire E1-510-2500 RAM Card Replacement: 步骤 5 中的图像 2,2
    • Use a plastic opening tool to carefully pry the back panel from its home.
    • When reassembling, insert the panel from the edge opposite the screw first.
  6. Acer Aspire E1-510-2500 RAM Card Replacement: 步骤 6 中的图像 1,3 Acer Aspire E1-510-2500 RAM Card Replacement: 步骤 6 中的图像 2,3 Acer Aspire E1-510-2500 RAM Card Replacement: 步骤 6 中的图像 3,3
    • Locate the tabs on either side of the RAM card.
    • Push out on both tabs simultaneously to release the RAM card.
    • The RAM card should raise slightly at the unattached edge.
  7. Acer Aspire E1-510-2500 RAM Card Replacement: 步骤 7 中的图像 1,2 Acer Aspire E1-510-2500 RAM Card Replacement: 步骤 7 中的图像 2,2
    • Carefully remove the RAM card from its home.
结论
另外一个人完成了本指南。
Sebastian Taylor
于10/19/17注册
733 声望
创作了6篇指南
团队
UMass Dartmouth, Team S2-G5, Julie Fall 2017 UMass Dartmouth, Team S2-G5, Julie Fall 2017 的会员
UMASSD-JULIE-F17S2G5
3 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 4
过去 30 天: 19
总计 571
