跳转到主内容
Acer Aspire E1-470P-6659 Motherboard Replacement
你所需要的
  1. Acer Aspire E1-470P-6659 Motherboard Replacement, Battery: 步骤 1 中的图像 1,1
    • Turn off the laptop and disconnect all device cords.
  2. Acer Aspire E1-470P-6659 Motherboard Replacement: 步骤 2 中的图像 1,1
    • Flip the laptop over so the bottom is facing you.
  3. Acer Aspire E1-470P-6659 Motherboard Replacement: 步骤 3 中的图像 1,3 Acer Aspire E1-470P-6659 Motherboard Replacement: 步骤 3 中的图像 2,3 Acer Aspire E1-470P-6659 Motherboard Replacement: 步骤 3 中的图像 3,3
    • Use your finger or a spuger to pull the battery release switch.
  4. Acer Aspire E1-470P-6659 Motherboard Replacement: 步骤 4 中的图像 1,3 Acer Aspire E1-470P-6659 Motherboard Replacement: 步骤 4 中的图像 2,3 Acer Aspire E1-470P-6659 Motherboard Replacement: 步骤 4 中的图像 3,3
    • Remove the battery from the laptop.
  5. Acer Aspire E1-470P-6659 Motherboard Replacement, Hard Drive: 步骤 5 中的图像 1,2 Acer Aspire E1-470P-6659 Motherboard Replacement, Hard Drive: 步骤 5 中的图像 2,2
    • Remove nineteen screws from the back panel using a Phillips #0 Screwdriver .
  6. Acer Aspire E1-470P-6659 Motherboard Replacement: 步骤 6 中的图像 1,3 Acer Aspire E1-470P-6659 Motherboard Replacement: 步骤 6 中的图像 2,3 Acer Aspire E1-470P-6659 Motherboard Replacement: 步骤 6 中的图像 3,3
    • Run the plastic opening tool across from one corner to another along the edge.
    • Separate the keyboard panel gently.
    • Lift the keyboard slowly from the laptop but do not lift completely because there are ribbon cables attached.
  7. Acer Aspire E1-470P-6659 Motherboard Replacement: 步骤 7 中的图像 1,2 Acer Aspire E1-470P-6659 Motherboard Replacement: 步骤 7 中的图像 2,2
    • Disconnect the two keyboard assembly ribbon cables from motherboard.
    • To release small ribbon cable, use spudger or fingers to flip gray bar along edge over.
    • To release larger ribbon cable, use pry tool or spudger to slide white plastic clip forward.
  8. Acer Aspire E1-470P-6659 Motherboard Replacement: 步骤 8 中的图像 1,1
    • Pull up the release tab beside the hard drive.
    • Disconnect portion of ribbon cable that is covering the hard drive.
    • Handle the ribbon carefully. Do not break the metal contact.
    • While reconnecting the ribbon after replacing a new hard drive, face the blue side with a label up. Make sure the black line beside the sticker is not crooked, so that the ribbon is tight.
  9. Acer Aspire E1-470P-6659 Motherboard Replacement: 步骤 9 中的图像 1,1
    • Remove the hard drive screw using Phillips #0 Screwdriver.
  10. Acer Aspire E1-470P-6659 Motherboard Replacement: 步骤 10 中的图像 1,1
    • Pull the hard drive out gently. Be aware that it is connected to the adapter.
    • Gently remove adapter by pulling on both ends simultaneously to separate it from the hard drive.
  11. Acer Aspire E1-470P-6659 Motherboard Replacement, Motherboard: 步骤 11 中的图像 1,3 Acer Aspire E1-470P-6659 Motherboard Replacement, Motherboard: 步骤 11 中的图像 2,3 Acer Aspire E1-470P-6659 Motherboard Replacement, Motherboard: 步骤 11 中的图像 3,3
    • Remove additional screws that can be found on the motherboard.
    • Remove the green wifi card from motherboard.
    • Use spudger to disconnect the fan and motherboard from laptop.
  12. Acer Aspire E1-470P-6659 Motherboard Replacement: 步骤 12 中的图像 1,2 Acer Aspire E1-470P-6659 Motherboard Replacement: 步骤 12 中的图像 2,2
    • Remove the cable attached to motherboard.
    • Gently lift and remove the motherboard from the laptop.
结论
Faith Lobaton
于10/22/18注册
497 声望
创作了3篇指南
团队
UC Davis, Team S4-G5, Lore Fall 2018 UC Davis, Team S4-G5, Lore Fall 2018 的会员
UCD-LORE-F18S4G5
3 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 6
过去 30 天: 21
总计 925
