简介
If you have problems with the laptop heating up, or the cooling fans need to be replaced or repaired, use this guide to remove and replace your laptop’s cooling fans.
你所需要的
Remove additional screws that can be found on the motherboard.
Remove the green wifi card from motherboard.
Use spudger to disconnect the fan and motherboard from laptop.
Flip the motherboard and fan piece over.
Remove the four screws using the Phillips #000 Screwdriver.
即将完成!
结论
