跳转到主内容
Acer Aspire E1-470P-6659 LCD Panel & Faceplate Replacement
你所需要的
  1. Acer Aspire E1-470P-6659  LCD Panel & Faceplate Replacement, Battery: 步骤 1 中的图像 1,1
    • Turn off the laptop and disconnect all device cords.
  2. Acer Aspire E1-470P-6659  LCD Panel & Faceplate Replacement: 步骤 2 中的图像 1,1
    • Flip the laptop over so the bottom is facing you.
  3. Acer Aspire E1-470P-6659  LCD Panel & Faceplate Replacement: 步骤 3 中的图像 1,3 Acer Aspire E1-470P-6659  LCD Panel & Faceplate Replacement: 步骤 3 中的图像 2,3 Acer Aspire E1-470P-6659  LCD Panel & Faceplate Replacement: 步骤 3 中的图像 3,3
    • Use your finger or a spuger to pull the battery release switch.
  4. Acer Aspire E1-470P-6659  LCD Panel & Faceplate Replacement: 步骤 4 中的图像 1,3 Acer Aspire E1-470P-6659  LCD Panel & Faceplate Replacement: 步骤 4 中的图像 2,3 Acer Aspire E1-470P-6659  LCD Panel & Faceplate Replacement: 步骤 4 中的图像 3,3
    • Remove the battery from the laptop.
  5. Acer Aspire E1-470P-6659  LCD Panel & Faceplate Replacement, LCD Panel & Faceplate: 步骤 5 中的图像 1,1
    • Locate the screws connected to the hinge of the laptop. Small, black stickers hide them from immediate view.
  6. Acer Aspire E1-470P-6659  LCD Panel & Faceplate Replacement: 步骤 6 中的图像 1,3 Acer Aspire E1-470P-6659  LCD Panel & Faceplate Replacement: 步骤 6 中的图像 2,3 Acer Aspire E1-470P-6659  LCD Panel & Faceplate Replacement: 步骤 6 中的图像 3,3
    在这个步骤中使用的工具:
    购买
    • On both corners, use tweezers to remove small plastic sticker hiding the screws.
    • Remove screws using Phillips #0 screwdriver.
  7. Acer Aspire E1-470P-6659  LCD Panel & Faceplate Replacement: 步骤 7 中的图像 1,3 Acer Aspire E1-470P-6659  LCD Panel & Faceplate Replacement: 步骤 7 中的图像 2,3 Acer Aspire E1-470P-6659  LCD Panel & Faceplate Replacement: 步骤 7 中的图像 3,3
    • Turn the laptop over and open it up.
    • Using a prying tool, run along all edges of the display to pry the front face plate from the cover.
    • Use your fingers to pull the LCD panel and faceplate from the backing.
  8. Acer Aspire E1-470P-6659  LCD Panel & Faceplate Replacement: 步骤 8 中的图像 1,3 Acer Aspire E1-470P-6659  LCD Panel & Faceplate Replacement: 步骤 8 中的图像 2,3 Acer Aspire E1-470P-6659  LCD Panel & Faceplate Replacement: 步骤 8 中的图像 3,3
    • LCD with faceplate should separate, be careful not to pull completely away because there is a cable still attached to the display.
    • Carefully peel tape away from cable lead and separate cable from LCD panel.
  9. Acer Aspire E1-470P-6659  LCD Panel & Faceplate Replacement: 步骤 9 中的图像 1,1
    • Remove the LCD Panel and faceplate from the device.
结论
Joel Humes
于10/22/18注册
163 声望
撰写一个指南
团队
UC Davis, Team S4-G5, Lore Fall 2018 UC Davis, Team S4-G5, Lore Fall 2018 的会员
UCD-LORE-F18S4G5
3 名成员
创作了5篇指南
一条评论
Need more guide how to safe instal lcd, cause peel tape and need new one.. Overall good and detail love it
Kusuma Wijaya - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 8
总计 556
