跳转到主内容
Acer Aspire E 11 RAM Replacement
你所需要的
  1. Acer Aspire E 11 RAM Replacement, Lower Case: 步骤 1 中的图像 1,2 Acer Aspire E 11 RAM Replacement, Lower Case: 步骤 1 中的图像 2,2
    • Unscrew the thirteen 6.2mm Phillips #1 screws located on the bottom of the device.
  2. Acer Aspire E 11 RAM Replacement: 步骤 2 中的图像 1,3 Acer Aspire E 11 RAM Replacement: 步骤 2 中的图像 2,3 Acer Aspire E 11 RAM Replacement: 步骤 2 中的图像 3,3
    • Lift the back panel using a plastic opening tool. Slowly make your way around the device until the back panel comes off.
  3. Acer Aspire E 11 RAM Replacement, Battery: 步骤 3 中的图像 1,2 Acer Aspire E 11 RAM Replacement, Battery: 步骤 3 中的图像 2,2
    • Press and hold the small black button located on the motherboard just above the battery for five seconds.
  4. Acer Aspire E 11 RAM Replacement: 步骤 4 中的图像 1,3 Acer Aspire E 11 RAM Replacement: 步骤 4 中的图像 2,3 Acer Aspire E 11 RAM Replacement: 步骤 4 中的图像 3,3
    • Using two plastic opening tools tightly grab the connector going from the battery to the motherboard and pull to unplug.
  5. Acer Aspire E 11 RAM Replacement: 步骤 5 中的图像 1,3 Acer Aspire E 11 RAM Replacement: 步骤 5 中的图像 2,3 Acer Aspire E 11 RAM Replacement: 步骤 5 中的图像 3,3
    • Unscrew two 6.2 mm Phillips #1 screws on the right and left sides of the battery.
  6. Acer Aspire E 11 RAM Replacement: 步骤 6 中的图像 1,1
    • Carefully remove the battery by lifting it out of the casing.
  7. Acer Aspire E 11 RAM Replacement, Motherboard: 步骤 7 中的图像 1,3 Acer Aspire E 11 RAM Replacement, Motherboard: 步骤 7 中的图像 2,3 Acer Aspire E 11 RAM Replacement, Motherboard: 步骤 7 中的图像 3,3
    • Locate the keyboard cable on the motherboard. Using, two plastic opening tools on each side of the connector, pull the two gray tabs outward and then remove the cable from the motherboard.
  8. Acer Aspire E 11 RAM Replacement: 步骤 8 中的图像 1,3 Acer Aspire E 11 RAM Replacement: 步骤 8 中的图像 2,3 Acer Aspire E 11 RAM Replacement: 步骤 8 中的图像 3,3
    • Use a plastic opening tool to carefully lift the white hinge up on the touchpad cable connector, and gently remove the cable from the motherboard.
  9. Acer Aspire E 11 RAM Replacement: 步骤 9 中的图像 1,3 Acer Aspire E 11 RAM Replacement: 步骤 9 中的图像 2,3 Acer Aspire E 11 RAM Replacement: 步骤 9 中的图像 3,3
    • Use two plastic opening tools to grip each side of the connector for the speaker cable and gently pull the cable from the motherboard.
  10. Acer Aspire E 11 RAM Replacement: 步骤 10 中的图像 1,3 Acer Aspire E 11 RAM Replacement: 步骤 10 中的图像 2,3 Acer Aspire E 11 RAM Replacement: 步骤 10 中的图像 3,3
    • Remove the tape on the connector for the display cable.
    • Use two plastic opening tools to grip each side of the connector and gently pull the display cable from the motherboard.
  11. Acer Aspire E 11 RAM Replacement: 步骤 11 中的图像 1,2 Acer Aspire E 11 RAM Replacement: 步骤 11 中的图像 2,2
    • Remove one 6.2 mm Phillips #1 screw from the wireless chip on the left side of the motherboard.
  12. Acer Aspire E 11 RAM Replacement: 步骤 12 中的图像 1,3 Acer Aspire E 11 RAM Replacement: 步骤 12 中的图像 2,3 Acer Aspire E 11 RAM Replacement: 步骤 12 中的图像 3,3
    • Remove three 6.2 mm Phillips #1 screws that attach the motherboard to the laptop casing.
  13. Acer Aspire E 11 RAM Replacement: 步骤 13 中的图像 1,1
    • Return to the wireless chip and gently pull it from the connector on the side of the motherboard.
  14. Acer Aspire E 11 RAM Replacement: 步骤 14 中的图像 1,1
    • The motherboard can now be lifted out from the laptop casing.
  15. Acer Aspire E 11 RAM Replacement, RAM: 步骤 15 中的图像 1,3 Acer Aspire E 11 RAM Replacement, RAM: 步骤 15 中的图像 2,3 Acer Aspire E 11 RAM Replacement, RAM: 步骤 15 中的图像 3,3
    • Once the motherboard has been removed from the device, flip the motherboard over to reveal the RAM chip.
    • Using your thumbs slide RAM card down and out of its slot.
结论
2等其他人完成本指南。
Robert Cobaich
于09/03/15注册
2,073 声望
创作了3篇指南
团队
USF Tampa, Team 16-1, Blackwell Winter 2016 USF Tampa, Team 16-1, Blackwell Winter 2016 的会员
USFT-BLACKWELL-W16S16G1
4 名成员
创作了11篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 21
总计 3,049
