跳转到主内容
Acer Aspire E 11 Battery Replacement
你所需要的
  1. Acer Aspire E 11 Battery Replacement, Lower Case: 步骤 1 中的图像 1,2 Acer Aspire E 11 Battery Replacement, Lower Case: 步骤 1 中的图像 2,2
    • Unscrew the thirteen 6.2mm Phillips #1 screws located on the bottom of the device.
  2. Acer Aspire E 11 Battery Replacement: 步骤 2 中的图像 1,3 Acer Aspire E 11 Battery Replacement: 步骤 2 中的图像 2,3 Acer Aspire E 11 Battery Replacement: 步骤 2 中的图像 3,3
    • Lift the back panel using a plastic opening tool. Slowly make your way around the device until the back panel comes off.
  3. Acer Aspire E 11 Battery Replacement, Battery: 步骤 3 中的图像 1,2 Acer Aspire E 11 Battery Replacement, Battery: 步骤 3 中的图像 2,2
    • Press and hold the small black button located on the motherboard just above the battery for five seconds.
  4. Acer Aspire E 11 Battery Replacement: 步骤 4 中的图像 1,3 Acer Aspire E 11 Battery Replacement: 步骤 4 中的图像 2,3 Acer Aspire E 11 Battery Replacement: 步骤 4 中的图像 3,3
    • Using two plastic opening tools tightly grab the connector going from the battery to the motherboard and pull to unplug.
  5. Acer Aspire E 11 Battery Replacement: 步骤 5 中的图像 1,3 Acer Aspire E 11 Battery Replacement: 步骤 5 中的图像 2,3 Acer Aspire E 11 Battery Replacement: 步骤 5 中的图像 3,3
    • Unscrew two 6.2 mm Phillips #1 screws on the right and left sides of the battery.
  6. Acer Aspire E 11 Battery Replacement: 步骤 6 中的图像 1,1
    • Carefully remove the battery by lifting it out of the casing.
结论
8等其他人完成本指南。
团队
USF Tampa, Team 16-1, Blackwell Winter 2016 USF Tampa, Team 16-1, Blackwell Winter 2016 的会员
USFT-BLACKWELL-W16S16G1
4 名成员
创作了11篇指南
5条评论
Excellent instructions, very precise and easy to follow. Great job!!!!
[deleted] - 回复
Can I remove the battery and use only the ac adapter to power it? Will it work and not cause damage to the unit?
json_viray - 回复
when you take the battery out it works ok and when you put the battery the orange light when take out the battery its fine could it be the battery or board connector
steve varney - 回复
when battery is out it works fine when connect out and orange and blue light come on then no display remove battery every returns to normal
steve varney - 回复
Thanks - battery replacement carried out successfully by a technical incompetent! This step-by-step guide is much clearer and easier to follow than a video - wish there were more like this out there.
willstac1 - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 7
过去 30 天: 19
总计 10,805
