跳转到主内容
简介
For this guide you will need a phillips screwdriver. Before beginning, make sure you completely power down your laptop and remove the battery.
配件
没有特定配件。
  1. Unlock the battery release by sliding it to the right.
    • Unlock the battery release by sliding it to the right.
  2. Slide the release button and remove the battery. Slide the release button and remove the battery.
    • Slide the release button and remove the battery.
  3. Using the Phillips #1 screwdriver, unscrew the single screw and remove the cover.
    • Using the Phillips #1 screwdriver, unscrew the single screw and remove the cover.
    • Ensure the computer is powered off and the battery is removed.
  4. Push the side of the clips away from each other to release the RAM. Remove the RAM from the device. Push the side of the clips away from each other to release the RAM. Remove the RAM from the device.
    • Push the side of the clips away from each other to release the RAM. Remove the RAM from the device.
结论
0条评论
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 4
总计 42
