跳转到主内容
Acer Aspire 8735G Memory (RAM) Replacement
你所需要的
  1. Acer Aspire 8735G Memory (RAM) Replacement, Battery: 步骤 1 中的图像 1,1
    • Before proceeding, power down your Laptop and remove the power cable.
    • Close the display and lay it on a flat surface, top-side down.
  2. Acer Aspire 8735G Memory (RAM) Replacement: 步骤 2 中的图像 1,1
    • Unlock the battery by sliding the battery lock to the unlock part.
  3. Acer Aspire 8735G Memory (RAM) Replacement: 步骤 3 中的图像 1,1
    • Slide the middle lock to the right and the battery will pop up.
  4. Acer Aspire 8735G Memory (RAM) Replacement: 步骤 4 中的图像 1,1
    • If you want to replace the battery and nothing else then now is the time to do so.
    • Once the battery hatch is unlocked you can now safely remove the battery.
  5. Acer Aspire 8735G Memory (RAM) Replacement, RAM: 步骤 5 中的图像 1,1
    在这个步骤中使用的工具:
    iFixit Precision 4 mm Screwdriver Bit
    $2.99
    购买
    • Use a Philips J1 driver to remove eight screws securing the bottom case.
    • Remove all of the 8 screws. After that you are in.
  6. Acer Aspire 8735G Memory (RAM) Replacement: 步骤 6 中的图像 1,1
    • Now try to spot the Memory, which is here indistinguishable as a red circle.
  7. Acer Aspire 8735G Memory (RAM) Replacement: 步骤 7 中的图像 1,1
    • Don't remove the ram before pushing the pins.
    • After the previous step, remove the ram by pushing the pins holding it outwards.
  8. Acer Aspire 8735G Memory (RAM) Replacement: 步骤 8 中的图像 1,1
    • If you need to change your memory and nothing else then now is the time to do so. The Acer Aspire 8735G takes DDR3 SO-DIMM ram, upgradeable up-to 8GB.
    • After that the pins jump up and you can carefully remove the ram.
结论
另外一个人完成了本指南。
Regome
于01/20/23注册
767 声望
创作了7篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 14
总计 95
