跳转到主内容
Acer Aspire 6530-6522 RAM Replacement
你所需要的
  1. Acer Aspire 6530-6522 RAM Replacement, Battery: 步骤 1 中的图像 1,2 Acer Aspire 6530-6522 RAM Replacement, Battery: 步骤 1 中的图像 2,2
    • Make sure the device is unplugged and completely powered down.
    • Turn the device over.
  2. Acer Aspire 6530-6522 RAM Replacement: 步骤 2 中的图像 1,2 Acer Aspire 6530-6522 RAM Replacement: 步骤 2 中的图像 2,2
    • The lock switch can slide either towards or away from the battery. If it is pushed towards the battery, the release switch is locked and the battery can not be released.
    • Slide the switch away from the battery.
  3. Acer Aspire 6530-6522 RAM Replacement: 步骤 3 中的图像 1,3 Acer Aspire 6530-6522 RAM Replacement: 步骤 3 中的图像 2,3 Acer Aspire 6530-6522 RAM Replacement: 步骤 3 中的图像 3,3
    • The battery release switch is just to the inside of the battery and slides parallel to it.
    • Push the switch to the side. It is not just an open or close switch, it actually pops the battery up so you will feel some resistance.
    • When inserting a battery back into the device, you do not need to touch this switch. Just press the battery firmly down, you will see and hear this switch catch.
  4. Acer Aspire 6530-6522 RAM Replacement: 步骤 4 中的图像 1,3 Acer Aspire 6530-6522 RAM Replacement: 步骤 4 中的图像 2,3 Acer Aspire 6530-6522 RAM Replacement: 步骤 4 中的图像 3,3
    • Pull the battery up and out. Use a plastic opening tool if necessary.
  5. Acer Aspire 6530-6522 RAM Replacement, RAM: 步骤 5 中的图像 1,2 Acer Aspire 6530-6522 RAM Replacement, RAM: 步骤 5 中的图像 2,2
    • Using a Phillips #1 screwdriver, remove the nine 7mm screws holding the back panel.
  6. Acer Aspire 6530-6522 RAM Replacement: 步骤 6 中的图像 1,1
    • Pull the release latches outward. The memory module should lift up.
    • Pull the memory up and out at about a 45 degree angle.
    • Repeat for the second module (if necessary).
结论
另外一个人完成了本指南。
Patrick McKenna
于03/20/18注册
656 声望
创作了5篇指南
团队
UMass Dartmouth, Team S5-G6, Peak Spring 2018 UMass Dartmouth, Team S5-G6, Peak Spring 2018 的会员
UMASSD-PEAK-S18S5G6
3 名成员
创作了8篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 10
总计 294
