跳转到主内容
Acer Aspire 5750-6677 Motherboard Replacement
你所需要的
  1. Acer Aspire 5750-6677 Motherboard Replacement, Battery Replacement: 步骤 1 中的图像 1,1
    • Flip the laptop over.
  2. Acer Aspire 5750-6677 Motherboard Replacement: 步骤 2 中的图像 1,1
    • Place a screw driver in the orange tab then slide to the right.
  3. Acer Aspire 5750-6677 Motherboard Replacement: 步骤 3 中的图像 1,1
    • Lift and remove the battery.
  4. Acer Aspire 5750-6677 Motherboard Replacement, Hard Drive: 步骤 4 中的图像 1,2 Acer Aspire 5750-6677 Motherboard Replacement, Hard Drive: 步骤 4 中的图像 2,2
    • Flip the device over so the backside is facing up.
    • Remove the two screws with the Phillips #0 screwdriver.
  5. Acer Aspire 5750-6677 Motherboard Replacement: 步骤 5 中的图像 1,2 Acer Aspire 5750-6677 Motherboard Replacement: 步骤 5 中的图像 2,2
    • Remove the cover to access the hard drive.
  6. Acer Aspire 5750-6677 Motherboard Replacement: 步骤 6 中的图像 1,1
    • Using the Phillips #0, remove the two screws holding the hard drive in.
  7. Acer Aspire 5750-6677 Motherboard Replacement: 步骤 7 中的图像 1,1
    • Pull the tab and lift up to remove the hard drive.
  8. Acer Aspire 5750-6677 Motherboard Replacement, Motherboard: 步骤 8 中的图像 1,2 Acer Aspire 5750-6677 Motherboard Replacement, Motherboard: 步骤 8 中的图像 2,2
    • Start by flipping the device over to expose the screws.
    • Remove ten screws with the Phillips #0 screwdriver.
  9. Acer Aspire 5750-6677 Motherboard Replacement: 步骤 9 中的图像 1,1
    • Using a Phillips #0 screwdriver, remove the four screws found under the battery.
  10. Acer Aspire 5750-6677 Motherboard Replacement: 步骤 10 中的图像 1,2 Acer Aspire 5750-6677 Motherboard Replacement: 步骤 10 中的图像 2,2
    • Flip the laptop back around so the Acer logo is facing upwards.
    • Open the laptop and using the iFixit opening tool, press the tabs in at the very top of the keyboard, in order to remove the keyboard.
  11. Acer Aspire 5750-6677 Motherboard Replacement: 步骤 11 中的图像 1,1
    • Use the Phillips #0 screwdriver to remove six screws.
    • Pull the top off of the keyboard to expose the motherboard.
  12. Acer Aspire 5750-6677 Motherboard Replacement: 步骤 12 中的图像 1,3 Acer Aspire 5750-6677 Motherboard Replacement: 步骤 12 中的图像 2,3 Acer Aspire 5750-6677 Motherboard Replacement: 步骤 12 中的图像 3,3
    • Remove the seven screws using the Phillips #0 screwdriver.
    • Detach any wires or cables that are attached to the motherboard.
    • Remove the motherboard.
结论
2等其他人完成本指南。
Dean Smith
于11/01/19注册
207 声望
撰写一个指南
团队
UMass Dartmouth, Team S1-G3, Valliere Fall 2019 UMass Dartmouth, Team S1-G3, Valliere Fall 2019 的会员
UMASSD-VALLIERE-F19S1G3
4 名成员
创作了3篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 11
过去 30 天: 45
总计 1,834
