跳转到主内容
Acer Aspire 5750-6667 Memory Replacement
你所需要的
  1. Acer Aspire 5750-6667 Memory Replacement, Battery: 步骤 1 中的图像 1,2 Acer Aspire 5750-6667 Memory Replacement, Battery: 步骤 1 中的图像 2,2
    • Unplug the charging cable from the laptop and the wall. Failure to disconnect the charging cable could result in electric shock.
    • Turn the laptop over.
    • Locate the orange switch next to the battery.
  2. Acer Aspire 5750-6667 Memory Replacement: 步骤 2 中的图像 1,3 Acer Aspire 5750-6667 Memory Replacement: 步骤 2 中的图像 2,3 Acer Aspire 5750-6667 Memory Replacement: 步骤 2 中的图像 3,3
    在这个步骤中使用的工具:
    购买
    • Using a small tool such as tweezers or a pen, slide the orange switch completely to the left to unlock the battery.
    • While holding the orange switch in place, lift the battery by the lip and pull it away from the laptop.
  3. Acer Aspire 5750-6667 Memory Replacement, Bottom Access Panel: 步骤 3 中的图像 1,3 Acer Aspire 5750-6667 Memory Replacement, Bottom Access Panel: 步骤 3 中的图像 2,3 Acer Aspire 5750-6667 Memory Replacement, Bottom Access Panel: 步骤 3 中的图像 3,3
    • Flip the laptop over and locate the bottom access panel. It is opposite the battery.
    • Locate the 2 screws that hold the panel in place and unscrew them using a Phillips PH0 screwdriver.
  4. Acer Aspire 5750-6667 Memory Replacement: 步骤 4 中的图像 1,3 Acer Aspire 5750-6667 Memory Replacement: 步骤 4 中的图像 2,3 Acer Aspire 5750-6667 Memory Replacement: 步骤 4 中的图像 3,3
    • Use the blue plastic opening tool to lift the panel away from the laptop.
  5. Acer Aspire 5750-6667 Memory Replacement, RAM: 步骤 5 中的图像 1,3 Acer Aspire 5750-6667 Memory Replacement, RAM: 步骤 5 中的图像 2,3 Acer Aspire 5750-6667 Memory Replacement, RAM: 步骤 5 中的图像 3,3
    • Lift the clear plastic flap and locate the pair of metal brackets that are holding the top RAM in place.
    • Using your thumbs, push the brackets away from the RAM . It should pop up when released.
    • You can now gently pull the top RAM out of the laptop.
  6. Acer Aspire 5750-6667 Memory Replacement: 步骤 6 中的图像 1,3 Acer Aspire 5750-6667 Memory Replacement: 步骤 6 中的图像 2,3 Acer Aspire 5750-6667 Memory Replacement: 步骤 6 中的图像 3,3
    • Locate the second pair of metal clasps holding the bottom RAM in place.
    • Using your thumbs, push the brackets away from the RAM . The RAM board should pop up when released.
    • You can now gently pull the top RAM out of the laptop. Repeat for any other RAM boards that may be in the device.
结论
2等其他人完成本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 8
总计 889
