跳转到主内容
Acer Aspire 5749 Fan/HeatSink Replacement
你所需要的
  1. Acer Aspire 5749 Fan/HeatSink Replacement, Fan/HeatSink: 步骤 1 中的图像 1,3 Acer Aspire 5749 Fan/HeatSink Replacement, Fan/HeatSink: 步骤 1 中的图像 2,3 Acer Aspire 5749 Fan/HeatSink Replacement, Fan/HeatSink: 步骤 1 中的图像 3,3
    • Retrieve all Screw's from the bottom of the laptop and organize them into 2 different sets.
    • When removing the back cover gently press on audio connections on the back right of the laptop.
  2. Acer Aspire 5749 Fan/HeatSink Replacement: 步骤 2 中的图像 1,3 Acer Aspire 5749 Fan/HeatSink Replacement: 步骤 2 中的图像 2,3 Acer Aspire 5749 Fan/HeatSink Replacement: 步骤 2 中的图像 3,3
    • Carefully release and unplug every wire that connects to the fan.
  3. Acer Aspire 5749 Fan/HeatSink Replacement: 步骤 3 中的图像 1,3 Acer Aspire 5749 Fan/HeatSink Replacement: 步骤 3 中的图像 2,3 Acer Aspire 5749 Fan/HeatSink Replacement: 步骤 3 中的图像 3,3
    • Release the screw that connects the fan to the base of the laptop. Carefully remove your fan and heat sink.
    • Apply heat paste to the center before replacing the fan and heat sink. Then reinsert the screw and plugs.
结论
8等其他人完成本指南。
JeanChristophe
于11/19/10注册
523 声望
创作了3篇指南
5条评论
May need to expand the "apply heat paste to center" section. Need to remove old paste first, etc. etc. A good bird's eye view intro, though
polishtext4 - 回复
Tanks you…
I'll look forward for adding this info.
JeanChristophe -
Seemed like I was going to rip the motherboard up where the usb ports are by the audio connector, why isn't the %#*@ thing screwed down? Lol If I push down by the audio connector like you mention and pull it up from the other side will ot be fine, felt and looked like I might snap the board.
Clayton Boyle - 回复
Good job, did have to Emphasis about releasing the audio connectors
Thaine Ferris - 回复
I didn't know how to explain better…
Some trick of trade?
JeanChristophe -
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 23
总计 7,706
