跳转到主内容
Acer Aspire 5742 LCD Panel Replacement
你所需要的
  1. Acer Aspire 5742 LCD Panel Replacement, Battery: 步骤 1 中的图像 1,3 Acer Aspire 5742 LCD Panel Replacement, Battery: 步骤 1 中的图像 2,3 Acer Aspire 5742 LCD Panel Replacement, Battery: 步骤 1 中的图像 3,3
    • Move the battery catch to the "unlocked" position.
    • Pull back the second spring-loaded battery catch until the battery pops up.
    • Remove the battery.
  2. Acer Aspire 5742 LCD Panel Replacement, Screen bezel screws: 步骤 2 中的图像 1,1
    • Open the laptop lid as far as it will go. Using a small craft knife or similar, remove the two black adhesive screw covers on either side of the screen at the bottom, by inserting the tip of the blade under the edge of the cover.
    • Remove the 2 screws now revealed.
  3. Acer Aspire 5742 LCD Panel Replacement, Removing the screen bezel: 步骤 3 中的图像 1,1
    • Separate the bezel around the screen by using a jimmy or similar tool to release the clips holding it in place. Work around both sides and the top. Finally, turn the laptop on its side in order to work along the bottom. You should now be able to lift off the bezel.
  4. Acer Aspire 5742 LCD Panel Replacement, Removing the LCD panel: 步骤 4 中的图像 1,1
    • Remove 2 screws from the bottom of the LCD panel.
    • At the top of the LCD panel, remove the 2 screws furthest from the corners. Support the panel as you remove these screws.
    • Very gently angle the LCD panel forwards and lay it face down.
  5. Acer Aspire 5742 LCD Panel Replacement, Disconnecting the video cable: 步骤 5 中的图像 1,1
    • Gently lift the transparent adhesive film covering the video connector on the back of the LCD panel, and disconnect the connector.
    • You can now completely remove the LCD panel.
结论
Philip Le Riche
于02/18/14注册
30,083 声望
创作了47篇指南
团队
Restart Project Restart Project 的会员
Community
18 名成员
创作了498篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 12
总计 1,380
