跳转到主内容
Acer Aspire 5742 Keyboard Replacement
你所需要的
  1. Acer Aspire 5742 Keyboard Replacement, Battery: 步骤 1 中的图像 1,3 Acer Aspire 5742 Keyboard Replacement, Battery: 步骤 1 中的图像 2,3 Acer Aspire 5742 Keyboard Replacement, Battery: 步骤 1 中的图像 3,3
    • Move the battery catch to the "unlocked" position.
    • Pull back the second spring-loaded battery catch until the battery pops up.
    • Remove the battery.
  2. Acer Aspire 5742 Keyboard Replacement, Keyboard: 步骤 2 中的图像 1,3 Acer Aspire 5742 Keyboard Replacement, Keyboard: 步骤 2 中的图像 2,3 Acer Aspire 5742 Keyboard Replacement, Keyboard: 步骤 2 中的图像 3,3
    • Unfold the laptop so that you are looking at the keyboard.
    • At the top right of the keyboard you will notice two clips above the 'Del' and 'End' keys.
    • Using your spudger, press these clips in to unlock the keyboard from the laptop
    • Be careful not to press too forcefully on these clips with the spudger as they may break
    • Slide the spudger along the top of the keyboard until the keyboard is able to easily be lifted up out of the laptop
    • Do NOT attempt to fully remove the keyboard as there is still a cable on its backside connected to the computer that can be damaged
  3. Acer Aspire 5742 Keyboard Replacement: 步骤 3 中的图像 1,3 Acer Aspire 5742 Keyboard Replacement: 步骤 3 中的图像 2,3 Acer Aspire 5742 Keyboard Replacement: 步骤 3 中的图像 3,3
    • Now that the keyboard is outside of the laptop, you will see a ribbon cable coming from the back of the keyboard connected to the laptop.
    • To detach this cable you must use the pointed edge of the spudger to press down on the locking mechanisms on each side.
    • Do not use too much pressure when disconnecting the ZIF connector.
    • After unlocking both sides of the ZIF connector remove the keyboard for replacement.
结论
6等其他人完成本指南。
Bill Murray
于10/24/16注册
581 声望
创作了2篇指南
团队
UMass Dartmouth, Team 2-6, Isaacson Fall 2016 UMass Dartmouth, Team 2-6, Isaacson Fall 2016 的会员
UMASSD-ISAACSON-F16S2G6
3 名成员
创作了8篇指南
2条评论
Ik zie het vergrendelingsmechanisme bij stap drie niet. Wat ik ook naar beneden druk hij de kabel wil niet loslaten. Moet de klem misschien omhoog?
Hans Hendriks - 回复
Sehen Sie sich 认识和断开线缆连接头 an. Möglicherweise gibt es eine Verriegelungsstange, die Sie anheben (Schritt 1) oder eine Stange, die Sie vorsichtig auf die andere Seite des Steckers drücken müssen (Schritt 7). Sobald Sie es ausgearbeitet haben, ist es einfach. (Beschuldigen Sie Google Translate, wenn dies keinen Sinn ergibt!)
Philip Le Riche - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 23
总计 6,426
