跳转到主内容
本指南有最近更改,您可查看未经巡查的最新版本
Acer Aspire 5742 Hard Drive Removal
你所需要的
  1. Acer Aspire 5742 Hard Drive Removal, Battery: 步骤 1 中的图像 1,3 Acer Aspire 5742 Hard Drive Removal, Battery: 步骤 1 中的图像 2,3 Acer Aspire 5742 Hard Drive Removal, Battery: 步骤 1 中的图像 3,3
    • Move the battery catch to the "unlocked" position.
    • Pull back the second spring-loaded battery catch until the battery pops up.
    • Remove the battery.
  2. Acer Aspire 5742 Hard Drive Removal, Cover Panel: 步骤 2 中的图像 1,3 Acer Aspire 5742 Hard Drive Removal, Cover Panel: 步骤 2 中的图像 2,3 Acer Aspire 5742 Hard Drive Removal, Cover Panel: 步骤 2 中的图像 3,3
    • Turn the notebook around to face you.
    • There are two Phillips #00 screws securing the cover panel to the rest of the notebook. Remove these screws.
  3. Acer Aspire 5742 Hard Drive Removal: 步骤 3 中的图像 1,3 Acer Aspire 5742 Hard Drive Removal: 步骤 3 中的图像 2,3 Acer Aspire 5742 Hard Drive Removal: 步骤 3 中的图像 3,3
    • Use a spudger to release the panel from the plastic retaining clips keeping it in place.
    • Do not apply too much force, or you may break the clips.
    • Remove the panel and set it aside.
  4. Acer Aspire 5742 Hard Drive Removal, Hard drive: 步骤 4 中的图像 1,3 Acer Aspire 5742 Hard Drive Removal, Hard drive: 步骤 4 中的图像 2,3 Acer Aspire 5742 Hard Drive Removal, Hard drive: 步骤 4 中的图像 3,3
    • Unscrew the Phillips #00 screw which retains the hard drive in place.
    • Gently slide the hard drive to the left in order to disengage the SATA connectors.
    • It may be quite stiff, in which case you can ease the hard drive out of the SATA connectors by inserting a spudger between the hard drive and the connector block.
    • Lift the drive out of the notebook.
结论
16等其他人完成本指南。
Skylar MacDonald
于12/04/11注册
1,964 声望
创作了5篇指南
4条评论
Great guide except for the missing screw sizes. Does anybody know the screw sizes?
patrickscott - 回复
I have this laptop with a bad HDD, it was a Toshiba 640 GB , 5400 RPM drive.
I like to know if this laptop supports 7200 RPM drives
Also, does this laptop support an SSD drive ?
Shahzaan - 回复
Yes, any 2.5in SATA HDD or SSD can be fitted in place of any other.
Philip Le Riche -
I love this guide! It's the best! Thank You!
Mark Wiens - 回复
添加评论
浏览统计数据:
过去 24 小时: 8
过去 7 天: 22
过去 30 天: 64
总计 45,273
