跳转到主内容
Acer Aspire 5742 CMOS Battery Replacement
你所需要的
  1. Acer Aspire 5742 CMOS Battery Replacement, Battery: 步骤 1 中的图像 1,3 Acer Aspire 5742 CMOS Battery Replacement, Battery: 步骤 1 中的图像 2,3 Acer Aspire 5742 CMOS Battery Replacement, Battery: 步骤 1 中的图像 3,3
    • Move the battery catch to the "unlocked" position.
    • Pull back the second spring-loaded battery catch until the battery pops up.
    • Remove the battery.
  2. Acer Aspire 5742 CMOS Battery Replacement, Cover Panel: 步骤 2 中的图像 1,3 Acer Aspire 5742 CMOS Battery Replacement, Cover Panel: 步骤 2 中的图像 2,3 Acer Aspire 5742 CMOS Battery Replacement, Cover Panel: 步骤 2 中的图像 3,3
    • Turn the notebook around to face you.
    • There are two Phillips #00 screws securing the cover panel to the rest of the notebook. Remove these screws.
  3. Acer Aspire 5742 CMOS Battery Replacement: 步骤 3 中的图像 1,3 Acer Aspire 5742 CMOS Battery Replacement: 步骤 3 中的图像 2,3 Acer Aspire 5742 CMOS Battery Replacement: 步骤 3 中的图像 3,3
    • Use a spudger to release the panel from the plastic retaining clips keeping it in place.
    • Do not apply too much force, or you may break the clips.
    • Remove the panel and set it aside.
  4. Acer Aspire 5742 CMOS Battery Replacement, CMOS Battery: 步骤 4 中的图像 1,2 Acer Aspire 5742 CMOS Battery Replacement, CMOS Battery: 步骤 4 中的图像 2,2
    • After removing the cover panel, you will see the hard drive, the RAM, and the CMOS battery.
    • The CMOS battery is the silver coin-like object in the center.
  5. Acer Aspire 5742 CMOS Battery Replacement: 步骤 5 中的图像 1,3 Acer Aspire 5742 CMOS Battery Replacement: 步骤 5 中的图像 2,3 Acer Aspire 5742 CMOS Battery Replacement: 步骤 5 中的图像 3,3
    • Press the tip of the spudger underneath the CMOS battery with very slight force.
    • Press down on the opposite side of the battery while prying the battery upward with the spudger.
    • After the battery is mostly lifted from the slot, you may pull out the battery with your fingers.
结论
8等其他人完成本指南。
Bill Murray
于10/24/16注册
581 声望
创作了2篇指南
团队
UMass Dartmouth, Team 2-6, Isaacson Fall 2016 UMass Dartmouth, Team 2-6, Isaacson Fall 2016 的会员
UMASSD-ISAACSON-F16S2G6
3 名成员
创作了8篇指南
一条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 21
过去 30 天: 91
总计 14,121
