简介
Use this guide to remove the WLAN module from your device.
你所需要的
步骤 1 Prepare Acer Aspire 5740-5780 for Disassembly
注意:步骤 1-4 源自标记为进行中的 指南。
Turn the laptop off and remove the power cord.
Put grounding strap on one of your wrists and attach the other end to a large metal object (recommended method).
If you don't have a grounding strap an alternative approach is to touch a metal object that is either large or connected to the earth. Then avoid doing things that would accumulate static electricity on your body.
即将完成!
结论
