跳转到主内容
Acer Aspire 5740-5780 RAM Replacement
你所需要的
  1. 注意:步骤 1-4 源自标记为进行中的 指南
    Acer Aspire 5740-5780 RAM Replacement, Prepare Acer Aspire 5740-5780 for Disassembly: 步骤 1 中的图像 1,2 Acer Aspire 5740-5780 RAM Replacement, Prepare Acer Aspire 5740-5780 for Disassembly: 步骤 1 中的图像 2,2
    • Turn the laptop off and remove the power cord.
  2. Acer Aspire 5740-5780 RAM Replacement: 步骤 2 中的图像 1,2 Acer Aspire 5740-5780 RAM Replacement: 步骤 2 中的图像 2,2
    • Press in the SD Card or the SD Card Dummy if no SD Card is there. Remove card when it pops out.
  3. Acer Aspire 5740-5780 RAM Replacement: 步骤 3 中的图像 1,1
    • Flip the laptop over on its face, so that the back is showing.
  4. Acer Aspire 5740-5780 RAM Replacement: 步骤 4 中的图像 1,1
    • Put grounding strap on one of your wrists and attach the other end to a large metal object (recommended method).
    • If you don't have a grounding strap an alternative approach is to touch a metal object that is either large or connected to the earth. Then avoid doing things that would accumulate static electricity on your body.
    • Touching the internals of your device while you aren't grounded could destroy your laptop.
  5. Acer Aspire 5740-5780 RAM Replacement, Battery: 步骤 5 中的图像 1,2 Acer Aspire 5740-5780 RAM Replacement, Battery: 步骤 5 中的图像 2,2
    • Unlock the battery by flipping a switch near the release latch.
  6. Acer Aspire 5740-5780 RAM Replacement: 步骤 6 中的图像 1,1
    • Slide the release latch to the left to release the battery from the PC.
  7. Acer Aspire 5740-5780 RAM Replacement: 步骤 7 中的图像 1,2 Acer Aspire 5740-5780 RAM Replacement: 步骤 7 中的图像 2,2
    • Use your hands to pry the battery free of the computer.
  8. Acer Aspire 5740-5780 RAM Replacement, RAM: 步骤 8 中的图像 1,1
    • Loosen the captive screw and remove the single M2.5 x L8 screw from the back panel using a Phillips #0 screwdriver.
  9. Acer Aspire 5740-5780 RAM Replacement: 步骤 9 中的图像 1,1
    • Gently pry off the panel with an opening tool. This will reveal the RAM.
  10. Acer Aspire 5740-5780 RAM Replacement: 步骤 10 中的图像 1,2 Acer Aspire 5740-5780 RAM Replacement: 步骤 10 中的图像 2,2
    • Use the opening tool to assist in carefully removing the RAM from the PC. Next lift the RAM up slowly and pull it out with your fingers.
结论
另外一个人完成了本指南。
Gian Farrell
于03/20/18注册
639 声望
创作了6篇指南
团队
UMass Dartmouth, Team S3-G6, Peak Spring 2018 UMass Dartmouth, Team S3-G6, Peak Spring 2018 的会员
UMASSD-PEAK-S18S3G6
3 名成员
创作了9篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 13
总计 688
